HawkinsHollow
I bought a used splitter a couple of months ago. Wondering if I should change fluid and filter. Couldn't hurt but how necessary is it?
It could accumulate water in it though- the breather lets in moist air as the tank warms and then it can condense when it cools.
When I changed the fluid in the used splitter I bought I filled it as full as I dared so there'd be less of an air space in the tank to "breathe".
Mine's got a 16 gpm pump. The manual says to put in 3.5-4 gallons. That's a lot less than the rule of thumb tank size = pump gpm. And yes the cylinder does get hot. When I changed the oil I put in 5, figuring that the worst that would happen is oil coming out the breather. That hasn't happened, so it's all good.
I am just a casual user of such equipment, so I don't really know what I am talking about, but it seems to me hydrualic oil and ATF would be fairly different, and using something other than what the equipment is designed for could shorten the service life?
Last winter I bought a used and abused log splitter. The hydraulic fluid was milky, there was no fluid filter, the engine oil was black, the spark plug was so rusted I wondered how in the **** the unit started when it was demonstrated to me! I don't know how the tires held together while I raced home down the highway, driving for at least an hour and a half! Did I mention I didn't know that the brake drums were rubbing! I never noticed any of these faults! I was blinded by the large splitting cylinder and large wheels to move it around. This splitter was a Wallenstein WX320, 3 pt hitch horizontal wood splitter, converted to a trailer mount splitter, 16" wheels, 5 gal fluid reservoir, 13 hp gas engine with a 16 gal/min hydraulic pump. Originally, this splitter would run off of one's tractor hydraulic fluid. However, from my research, all of Wallenstein's gas engine trailer style wood splitters use ATF fluid. That would lead me to believe, one could use hydraulic or ATF fluid with the trailer gas engine wood splitters!
With a new spark plug, a new carb ($20.00 shipped), flushing out the water and replacing the hydraulic fluid (good for -32 Celsius), adding a 1-1/4" in-line filter head with a 6.7" filter between the hydraulic reservoir and the hydraulic pump, not to forget, replaced the tires, All is well! My hydraulic oil does get warm, witch would help drive off any condensation that has accumulated. I need to monitor the temperature so it doesn't get too hot. I'm usually splitting when it about -10 celsius, and the hydraulic hoses are the extra long ones from the cylinder's 3 point hitch days, which help to release a lot of heat, from building up. My tractor has twice the hydraulic fluid, so if the splitter ran off it, the extra fluid could handle more heat and I would think, last longer between changes. I run my splitter for about 5 hours a stretch, always in the cold, keeping track of the hours and how hot it gets and how it sounds, how the fluid looks and feels! Hope that was somewhat helpful!!
You're right Dale, most filters give their pressure rating. I went to the technical data sheet for my filter, it gives both rating as a suction placed filter and a pressure placed filter (pressure rating is 4 x the suction rating). However, having a large volume of fluid at a low pressure going into my pump, I was forced to use a much larger filter and filter head, hoses etc., not to restrict the in flow. I was advised by a hydraulic specialist, that the best place was on the in-take side of the pump, as long as I used the larger set-up!
I started out with no filter at all. After draining the reservoir, sign of aluminum flakes were stuck to the bottom of the tank, most likely pump wear. I also wanted to install a bottom drain in the tank, for ease of draining. To help prolong the life of my pump, by filter out everything before it went in (including water, witch was and still may be a problem), I placed the filter just before the pump intake. Filtering before the hydraulic reservoir only requires a very small filter, which is much cheaper and better for the compact, streamlined units people like to buy and keeps the cost of the production of the wood splitter lower.
So, my tractor hydraulic system has a smaller filter than my splitter, but larger than the regular (after the pump) filter on the gas engine wood splitters. My tractor hydraulic filter is placed on the suction line and operates under similar before and after pump pressures as my wood splitter set-up. I like to try and understand how things can and should work. I like to have my ideas challenged, it's a part of my learning process. I don't believe everything I hear and need to see similar situations that validate the idea being studied. I have had "failures" in the past, nothing life threatening. Money can be replaced!
Thanks for your thoughts on filter placement! Did you see my posting on tractor diesel fuel filter placement. I went with the idea of someone, ( which made better sense, based on some of my previous experience), who posted a response, contrary to my idea, of the better placement. Down the road when another failure arises, I'll get to evaluate my set-up (most likely, pump failure).
