John Deere 2040 Electrical Wiring Schematic Help
   / John Deere 2040 Electrical Wiring Schematic Help #1
Moto101
John Deere 2040
I have a JD 2040 that I recently bought and the wiring is a mess. Everything is unplugged and none of the gages work. I need to rewire it but I dont have any schematics. does anyone have any schematics for it that you woud share with me?
Thank you
   / John Deere 2040 Electrical Wiring Schematic Help #2
Welcome to TBN
Have you considered purchasing a JD 2040 tech manual? There is a serial break @ 350000. I have a 2040 tech manual for lower serial # tractors but I have no way to scan it.
I purchased one online, actualy 2, but they both are for the 24V model and mine is a 12V. I have used what I can but really need to find the right manual or someone with the schematics. My serial number is lower than the 350000 that you mentioned.
Thank you
   / John Deere 2040 Electrical Wiring Schematic Help #4
I sold JD 2040's when they were brand new. I didn't realize any 2040 had 24 volt electrical system. I can't locate any 2040 with 24 volt electrical system in JD parts. Are you positive electrical system is for 24 volts or merely two 12 volt batteries attached in parallel for extra starting capacity?
My mistake. Thats what I meant. My tractor only has one 12V battery but the schematics are for two 12V batteries. The tach is also different. Im kind of leary of buying another manual online because I dont wont to end up with the same ones that I have. Im thinking that I may be able to put it back together with what I have and a multimeter. Thank you for you reply.
   / John Deere 2040 Electrical Wiring Schematic Help #6
For serial numbers <350000, the Tech manual is TM4300
   / John Deere 2040 Electrical Wiring Schematic Help #8
Zebrafive
The tech manual # you posted will be dependent on if Moto101's 2040 was built for sales in N America with 3 cyl engine or European countries with 4 cyl engine. Plus early 2040 built for N American sales up to serial # 266,750 had open center hyd's while later models had closed center hyd's.
Mine is a 3 cylinder diesel with a SN# less than 266,750. What is open and closed center hydraulics?
Thanks
   / John Deere 2040 Electrical Wiring Schematic Help #10
"With an open center system, flow is continuous and pressure is intermittent – which is contrary to a closed center system where the flow is intermittent and the pressure continuous."
Googled What is open and closed center hydraulics?. There are visuals too.
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
Category 3 Quick Hitch (A50514)
Category 3 Quick...
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2015 Toro Z Master Professional 64in Zero Turn Commercial Mower (A50322)
2015 Toro Z Master...
2012 International ProStar T/A Day Cab Truck Tractor (A50323)
2012 International...
