Ring under a Batwing Mower
   / Ring under a Batwing Mower #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
I'm not ready to buy a batwing yet, but I enjoy looking at what's out there. One of the things that I don't understand is the ring that goes around the stump jumper. What does it do?
   / Ring under a Batwing Mower #4
I would venture that it is to help with lift under the deck for finer material ?
Frank
Yeah I’d guess the same
Helps create a suction or vacuum to lift the grass or brush up into the blades for a better cut?
   / Ring under a Batwing Mower #5
When Bush Hog introduced the feature it was touted as protection for the deck.
you don’t see mower deck baffles to the center (inside) of the blade cutting edges.
   / Ring under a Batwing Mower #6
I would have called it a mulching kit. Any way to compare similar size mowers to see the residue stream ?
   / Ring under a Batwing Mower #7
I just brought this home last week. Land Pride. Looks different underneath.
   / Ring under a Batwing Mower #9
Keeps the blades from damaging the deck.
Yup, we had a couple of 20' batwing mowers we used for roadside and median clearing we pull behind a NH TV145. Couple years after purchase the decks were beat to death and I mean beat so much so that we scrapped one. Next one we bought had the rings under and it made a whole lot of difference to the amount of damage......Mike
   / Ring under a Batwing Mower #10
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
2018 PINSA 130BBL VACUUM TRAILER (A53843)
2018 PINSA 130BBL...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
2016 Ford F-550 Ext. Cab Flatbed Truck (A52377)
2016 Ford F-550...
2014 PETERBILT 388 (A53843)
2014 PETERBILT 388...
