Ring under a Batwing Mower
   / Ring under a Batwing Mower #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
I'm not ready to buy a batwing yet, but I enjoy looking at what's out there. One of the things that I don't understand is the ring that goes around the stump jumper. What does it do?
   / Ring under a Batwing Mower #4
I would venture that it is to help with lift under the deck for finer material ?
Frank
Yeah I’d guess the same
Helps create a suction or vacuum to lift the grass or brush up into the blades for a better cut?
   / Ring under a Batwing Mower #5
When Bush Hog introduced the feature it was touted as protection for the deck.
you don’t see mower deck baffles to the center (inside) of the blade cutting edges.
   / Ring under a Batwing Mower #6
I would have called it a mulching kit. Any way to compare similar size mowers to see the residue stream ?
   / Ring under a Batwing Mower #7
I just brought this home last week. Land Pride. Looks different underneath.
   / Ring under a Batwing Mower #9
Keeps the blades from damaging the deck.
Yup, we had a couple of 20' batwing mowers we used for roadside and median clearing we pull behind a NH TV145. Couple years after purchase the decks were beat to death and I mean beat so much so that we scrapped one. Next one we bought had the rings under and it made a whole lot of difference to the amount of damage......Mike
   / Ring under a Batwing Mower #10
2021 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2021 PRINOTH...
2011 SHOP BUILT FLARE STACK (A53843)
2011 SHOP BUILT...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
2007 GALYEAN 130BBL VAC TRAILER (A53843)
2007 GALYEAN...
FRONTIER MG20F LOT NUMBER 80 (A53084)
FRONTIER MG20F LOT...
2018 Freightliner M2 106 Altec LR756 Forestry Bucket Truck (A52377)
2018 Freightliner...
