Engine knock after injector pump and injector rebuild
   / Engine knock after injector pump and injector rebuild #1
IndyJay
S.E. Indiana
2021 Kioti DK4510MS w/Loader, Grapple Prev: Massey 1250
I have a 1994 MF1250 that I sent out for injection pump and injector rebuild. Came back 4 months and $2,800 later with a bad engine knock. I've had the tractor since it was new and had never heard it knocking. Any idea what it could be?
I know, 27 year old tractor, hours are unknown since tach hasn't worked for probably 20 years but looking for some things to check.
34HP Iseki TK532, 91.4ci/1.5L
Thanks!
Thanks Rick. Everything I hear points to injection but the dealer is insistent that the rebuilder has everything to spec. They pulled the head and oil pan, didn't see anything beyond what you would expect from a 27 year old tractor. Not sure how to proceed, they are saying that there will will be more charges for them to pull the pump and send it back. Is this something a dealer normally can do or is it best left to the rebuilders?
Thanks again, Jay
   / Engine knock after injector pump and injector rebuild #4
I'm saying it's HIGHLY probable the dealer installed the pump incorrectly; not timed correctly to the piston travel.
Not faulty injectors or an imperfect pump rebuild.
It didn't knock before they removed the pump and now it does. That's what I'm reading. Am I right?
Probably advanced more than it should be.
   / Engine knock after injector pump and injector rebuild #5
I'd try bleeding the fuel lines at the injectors before worrying about anything worse.
Rick, you are exactly right. Thanks for clarifying the specific likely cause.
   / Engine knock after injector pump and injector rebuild #7
yep this is what I was going to suggest because my tractor has knocked like he's stating twice once when it got water in the fuel and another time when I replaced the fuel filter and apparently got air in the line.
   / Engine knock after injector pump and injector rebuild #8
Thanks!
Time to bleed some fuel lines and make very sure the fuel is clean .
They did drain entire fuel system, new filters and fuel just as good practice.
Would assume that professional mechanics would know to bleed but I will certainly suggest that.
Much thanks to all who have replied. Should be an interesting conversation come Monday.
Hopefully it is one of these and I haven't thrown almost $3k out the window!
   / Engine knock after injector pump and injector rebuild #10
One other possibility is a crossed set of injector lines.
1979 MACK R MODEL (A53843)
1979 MACK R MODEL...
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2020 PRINOTH...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
2006 FORD F-350 (A53422)
2006 FORD F-350...
2011 Nissan Rogue SUV (A53424)
2011 Nissan Rogue...
