IBC Totes
   / IBC Totes #51
Anybody know what a tote full of firewood ways? Say filled to the top or slightly less.
Mine hold 1/3 cord and I estimate mine weigh 1300 lbs with fresh cut oak and maple which weighs about 4000 lbs a cord. When it dries it is a bit lighter. I notice the difference when I move them for the first time vs bringing them back to the house right before winter.
   / IBC Totes #52
Hello Shooterdon - Very impressed with the way you cut the bladders as shown in your picture #3. Since a tote that is filled with wood that is level to the top holds 3/8 of a cord - I estimate that I could hold 5/8 of a cord in each tote if I cut bladders in same manner as you. I am currently storing my wood in 20 totes and therefore could store an extra 5 cords in the same amount of space. Thanks very much for a great idea.
Thanks!
It takes about 45-60 minutes to modify one. Mine hold just under 1/2 cord. I have 32 totes...one just a cage. That gives me over two years of firewood. I used zip ties to attach the plastic bin. I am 70 so needed to find an easy way and cheap way. I doubt I will ever need more in my lifetime. I have $800 invested.
   / IBC Totes #54
Wow, got to save that craigslist ad for posterity:
   / IBC Totes #55
^ that boat is hillarious. Might be a bit tippy.
I figured I would snap a pic of my tote coverage for winter. Keeps the wood nice and dry, and pretty easy to deal with for quick on/off and tote swapping. Just two old cruddy sheets of plywood standing vertically in the middle of the stack, and the leftover tarp roof from a $99 carport. And tarp would do.
   / IBC Totes #56
I need to start looking for these, again... Like others have posted, prices seem to be all over the map. I stopped to look at some, coming back from deer hunting this fall. He wanted $125 each. :laughing:
   / IBC Totes #57
It seems like when they need the space, $$ comes down.
   / IBC Totes #58
I've been grabbing them from work when available, e leakers gets set out and they have to pay to dispose of them. Often have oil in them, normally less than a couple gallons, which I collect and dispose of properly. I cut the top off and put it back on, including the removable top ribs, and tack the sides with a few self drilling screws. Sawzall takes out a section of tubing to make side access, and forks on the tractor make them easy to move. I had about a dozen filled with firewood last fall, down to 3 now... we keep the house warm!
But the OP was what to do with the removed bladder...
I've done several things... the bottm that's missing the top I used for a firewood tote had collected junk barbed wire when we tore out old fence, cut the bottom off and the flat side panels were cut into 6' long strips and 2 used to make a hot tub cover winter roof, some were used as siding on a chicken coop wall, some used to cover truck parts (axles, transmissions, motors, etc) that were on pallets, covered with upside down bladder to make a roof... I'm gonna cut one up to make a cover for my cement mixer next.
   / IBC Totes #59
The bladder plastic can be heat formed. Play a propane torch over it until it turns clear then put it in the shape you need it and hold it there til it cools. Best to have a form to bend it over, and gloves if you need to touch the hot part.
   / IBC Totes #60
I just picked up a couple for $20.00 each. Now I'm wondering, once I fill them with wood it looks like it is going to be quite difficult to take it out without standing on my head.
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A52377)
2021 Allmand Bros...
2007 JLG SKYPOWER 800AJ TELESCOPIC MANLIFT (A52705)
2007 JLG SKYPOWER...
2008 Featherlite Trailer, VIN # 4FGE853218C108480 (A53424)
2008 Featherlite...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54313)
2019 INTERNATIONAL...
UNUSED Red Corrugated Polycarbonate Roof Panel (A53117)
UNUSED Red...
