Parts For Titan Hay Forks
   / Parts For Titan Hay Forks #1
wirlybird
Gold Member
Oklahoma
John Deere 3038 E, John Deere 3032E, John Deere 756, John Deere X585, John Deere 332
Hi all,
I just picked up a used Titan John Deere quick attach style hay fork.
It is missing one of the pins on the lower part for the JD quick attach.
Yellow arrows in picture show the item I need.
Anyone have any idea where to get these? I can see that they are welded on so should be pretty straight forward to replace.
I have sent a message to Titan so we'll see if I get an answer.
Thanks for any ideas.
   / Parts For Titan Hay Forks #2
I have purchased the pins and the upper mount directly from our local John Deere store/ LandPro. The upper mount and pin arrangement is the John Deere style of mounting. The lower pin is used for the larger 5000 series loaders with I think it has a 18" spread C/L. The upper pin is used on my 400 series loader at a 15" spread C/L. Depending upon which pin is missing and which loader frame you are using it may not be needed. Also I think they are plug welded from the back side so it may not be that easy to replace. The picture shows the mounting for a 5000 series tractor, my 4000 series tractor / 400 series loader used the upper pin which was not needed for the neighbors tractor.
My loader is a 300E and I have the unit on it. It uses the upper pins but one is missing and I'd like to replace it.
Yes, it looks like the pins are placed in a hole then welded from the "front" side of the unit.
So you were able to get the pins and upper curved mount part? This would be great for making my own attachment provided they are very costly!
   / Parts For Titan Hay Forks #5
Hi all,
The missing lower pin is not needed for 200-400 series loaders. Only need for thr 5000 series loaders.
Pins and hopks ate available in ebay or amazon. Or through many vendors or JD.
Upper pin is missing.
   / Parts For Titan Hay Forks #7
Is first photo with arrows the pallet fork frame in question. Looks like both pins are there.
Yes, that's the good side and was used just to point out the pin rather than me trying to explain and confusing things!!
UPDATE:
I found this hay spear is Titan Attachments and not Titan implements. Quick shout out to Titan Implements for sending me the correct way. Was nice of them to respond.
They have the pins listed and the price isn't too bad.
Here is the Amazon site. One thing I found I liked was you can buy a pair of the JD quick attach plates to make your own front implement! Scroll to the bottom of their page.
   / Parts For Titan Hay Forks #10
Ahhh. Understand. Is the pin sheared off, or just missing? I.E. is the hole there? From your pic, it appears that you have the hay spear only frame and have access to the back side for welding. I have the Titan Attachments fork frame with hay spear and hitch receiver. I think in paid under $300 for it direct from Titan. My only concern was that it collected rain water inside the top box section. Added drain holes on the bottokm side on the ends, and no more issue.
John Deere Z915E Zero Turn (A51573)
John Deere Z915E...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
TEST BID LOT (A50775)
WESSEX 1.5T LOT NUMBER 172 (A53084)
WESSEX 1.5T LOT...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket ONE PER LOT (A53472)
Kubota 24in Quick...
2017 FORD TRANSIT T150 CARGO VAN (A52577)
2017 FORD TRANSIT...
