Can a X738 front blade system be mounted on a rear three point?
   / Can a X738 front blade system be mounted on a rear three point? #1
jpmurf
Member
satoh
Can a X738 front blade system be mounted on a rear three point? I have a blade and a snow blower, it is a pain to swap them over, so I am thinking about adding 3 point, in order to mount the blade on the rear. That way I can push some piles around and have the best of both worlds. The swivel feature would be a bonus. Any insights?
   / Can a X738 front blade system be mounted on a rear three point? #2
Shouldn't be hard to attach your mounting / hydraulic assembly to a 3pt frame. The only issue I can see is all of the hydraulic connections you will need. Could be interesting ....
   / Can a X738 front blade system be mounted on a rear three point? #3
Go for it.. with some fabbing should work just fine. For starters a quick hitch like the iMatch would save some time and design work and be fast to connect up.
2016 FORD INTERCEPTOR (A51406)
2016 FORD...
Gooseneck Livestock Stock Trailer - Tandem Axle Ranch Hauler - Selling Absolute, No Reserve (A52748)
Gooseneck...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
2016 Chrysler 200 Limited Sedan (A51694)
2016 Chrysler 200...
