Almonzo
Anyone else have a JD 2640 and know where the starter relay is actually located? I have the tech manual, but the one pic it has for this is grainy and has an arrow pointing to (upper corner under the right cowl) what I've confirmed is actually the voltage regulator (which is square -- the relay is round). I've looked all around under both left and right cowls, under the gauge panel, around the battery area, etc., and just do not see it.
I'm suspecting the starter relay needs replaced, because I get no panel lights, no sound, when turning the key in the ignition. Even if the starter relay is not at fault, locating it would provide a helpful place to connect my volt meter, to troubleshoot what is happening.
Should mention: battery is good, has new ignition switch, have tried gear selector in both park and neutral (no gear) positions. In hindsight, i have seen this issue a few other times, but it seemed to resolve itself eventually.
Appreciate any ideas or info.
