Kubota BX25D - Backhoe return line/quick connect getting hot
   / Kubota BX25D - Backhoe return line/quick connect getting hot #1
analog
Member
somewhere, wa
kubota bx25d
Today I needed to swap out the backhoe for a tiller and when I was done and needed to reconnect the backhoe, I noticed the quick connect that goes back to the tractor from itself was hot to the touch, so much so that I had to very quickly undo it so I could get the backhoe line back on. Once it was on, and running for a few minutes, the return line from the backhoe got hot too. I smelled it and didn't smell any burned oil smell but it's definitely hot and not something I ever remember when doing this in the past. It was not hot when I went to take the backhoe off initially (even though I had been running it for a little while). I did add some hydraulic fluid today but I'm pretty sure I didn't add too much. I know people say that 90 degree bends like at that point can be a reason for them to get hot but again I never had this problem before that I remember. What should I look at? Thanks for any suggestions!
   / Kubota BX25D - Backhoe return line/quick connect getting hot #2
It’s a hydrostatic driven tractor, every time you move it heats all the hydraulic fluid to some extent. When you do hard work and work in low range it will get hotter. I don’t think it’s anything to worry about from the sounds off it. As long as it’s not smoking or evaporating water off the hose I wouldn’t worry about it.
   / Kubota BX25D - Backhoe return line/quick connect getting hot #3
Generally hydraulic fluid runs hot - hot enough that you don't want to handle the metal fittings with your bare hands. If you can connect and disconnect lines without acquiring first degree burns on your bare hands you're probably well within tolerances.
Any particular reason why that is the only fitting that's getting hot though? All the rest of them are cool to the touch.
   / Kubota BX25D - Backhoe return line/quick connect getting hot #5
My suggestion is get a cheap infrared temp gun and take some readings and post the temps. Take several readings of other fittings and document which is at what temperature. This will help everyone give you better directions.
Do you have a hose to loop the power into the backhoe back to the return when the backhoe is disconnected?
When you say the return is the only one getting hot, which other fittings are you comparing?
   / Kubota BX25D - Backhoe return line/quick connect getting hot #6
That is a continuous flow line so the fluid is always circulating vs say a loader hose that only gets fluid when you activate the cylinder and only hot fluid one way then likely cooler fluid on return.
   / Kubota BX25D - Backhoe return line/quick connect getting hot #7
Have you checked the couplers? If a male coupler is on the tractor side it might not getting opened with the female coupler.
The return line on the tractor is a female connection. Yes, when you disconnect the backhoe, you have to hook the line that goes into the backhoe back into the return line. It's set up so that you can't mess it up. The return line was getting hot regardless if the backhoe was getting disconnected or not. I fiddled with the connector thinking maybe it was getting restricted flow somehow but I'm not sure how that would be since everything seemed to operate normally - the connectors and also the backhoe works just fine.
I have a thermal camera, it's in my fire gear though so I won't be able to get it for a couple weeks, I'm on vacation. I'll post pics on this thread as soon as I can, that's a good idea!
   / Kubota BX25D - Backhoe return line/quick connect getting hot #10
If the return gets hot and the feed line doesn’t then I would say you have a restriction in that return fitting. Like what was already mentioned flow is continuous so they should both be the same temp. But they will be hotter than a fitting on the work ports of the loader or backhoe.
Look forward to seeing what the actual temps are. That will tell us a lot.
1999 Toro Reelmaster 5400-D 100in Fairway Reel Mower (A59228)
1999 Toro...
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
S/A Utility Trailer (A59231)
S/A Utility...
Rotary SPOA9-200 Automotive Lift (A56857)
Rotary SPOA9-200...
24017 (A56859)
24017 (A56859)
KUBOTA KX71-3 SUPER SERIES EXCAVATOR (A60429)
KUBOTA KX71-3...
