Brakes won’t release on 770 John Deere grader
   / Brakes won’t release on 770 John Deere grader #1
Da newfie
770 JD Grader
parked a 770 jd grader last fall and now she won’t go in gear because the parking brake won’t release. Any help would be greatly appreciated. Thanks in advance
   / Brakes won’t release on 770 John Deere grader #2
Hammer on the brakes to break up the corrosion bond possibly.
   / Brakes won’t release on 770 John Deere grader #3
Welcome to TBN
My inexperienced guess concerning JD industrial equipment tells me you probably have a parking brake control cable that needs lubrication such as PBBlaster, Kroil or similar penetrating fluid
   / Brakes won’t release on 770 John Deere grader #4
I had to hammer drum brakes on a customer's Honda civic and it was only parked over the weekend.
   / Brakes won’t release on 770 John Deere grader #5
His brakes are internal, oil bathed.
The park brake is electric over hydraulic.
To set the brake hydraulic pressure is released. This is logical so it doesn't slowly release after the machine is parked.
To release the brake hydraulic pressure is applied. This is accomplished with an electronic actuated solenoid.
I'm guessing you have lost electric power to the solenoid. Or the solenoid has failed.
Find the solenoid and check the circuit for power when the "key" is on. If no power, search for a fuse?
If the circuit powers up when the key is turned on then the problem is more than likely the solenoid.
Report back with your findings. Hope it's a simple fuse.
I've ran JD graders since 1989. Now running a JD 672G.
Welcome to TBN.
   / Brakes won’t release on 770 John Deere grader #6
   / Brakes won’t release on 770 John Deere grader #7
The 770 JD grader has been built over a span of 35-ish years. There are many model variations. I've operated 6 of those variations. The B version used a hand brake. Everything built since 1993-ish has been electric over hydraulic.
Since the OP didn't specify which model he's working on I simply assumed it was newer than 30 years old. If I'm mistaken I'm sorry.
If it's the older cable version make sure the actuating lever at the trans case is releasing.
   / Brakes won’t release on 770 John Deere grader #8
In reviewing TxJim's link. If it's that version the park brake has nothing to do with the trans not going into gear. This system uses a caliper on a spinning disc outside the trans. All it does is stop the trans from turning.
The later cable version uses the parking brake integrated internally in the trans. It will lock out the trans ability to go into gear. The more later versions used electric over hydraulic and also lock out the trans.
   / Brakes won’t release on 770 John Deere grader #9
ovrszd
Thanks for your explanation. I failed to locate another style parking brake control in the only JD parts catalog #1504 for 770. As I previously stated my experience with JD industrial tractors/implements is very limited
   / Brakes won’t release on 770 John Deere grader #10
No worries. To get a complete listing of JD grader models search "Construction" equipment rather than AG.
ATTENTION PLEASE READ (A50121)
ATTENTION PLEASE...
2014 John Deere 644K Articulated Wheel Loader (A50322)
2014 John Deere...
2004 Stage Line SL-250 Mobile Folding Stage Trailer (A50322)
2004 Stage Line...
2015 Big Tex 70PI 15ft Pipe Top T/A Utility Trailer (A50323)
2015 Big Tex 70PI...
2013 Honda CR-Z EX Hatchback (A50324)
2013 Honda CR-Z EX...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
