If your array is so big and payback period is so short, why not store this free energy in a usable battery, rather than use the grid as a battery and loose access when you need it most?
I just don't see the point of grid tied solar without a battery bank. It's just producing cheap power for the electric company.
I’m not sure how you are missing the point.
Size of the system is really irrelevant.
The energy is not free. The PV system has a cost.
Battery bank would double the cost of the system (at least) and likely have more continual cost and batteries have a more limited life span than PV panels and inverter.
There are some cases where batteries make more sense with utility peak rates (doesn’t apply to me) and I guess some backup power means, but it is generally a very small amount of backup. I can store far more power in diesel for the generator far more cheaply and far more reliably than trying to store in batteries for ‘utility outages’.
My power company pays me the exact same rate for power I supply to them as they supply to me. In my case it is very simple settled on a monthly basis.
Consumed power - generated power = delta * rate + base charge = Bill.
In my case the bill can’t be less than $0, so i sized my system accordingly to not provide the utility with ‘free power’. I should always have a +000kwh bill from my utility due to how their rules are setup and how I sized my system accordingly.
Others on this site have a settle up period at the end of the year which is a better deal than I have.
Seems maybe you don’t understand the economics around a grid tied system are are quick to bash what you don’t understand.
I didn’t forgo a battery system due to any other reason than the benefits for my situation come nowhere near the cost of such a system. A battery system would never pay for itself in my current situation with my utility.
