npalen
Elite Member
I use my Mahindra 3015 (30 HP wi hydrostat) quite a bit for roto-tilling and normally use the tractor clutch when engaging the mechanical PTO. I don't use the clutch for dis-engaging the PTO, however, but rather just move the PTO lever to the off position. The other day, for some reason, I pushed in the clutch to stop the tiller, and noticed a weird clunking noise in the transmission that sounded like some kind of over-running clutch as the tiller was coasting to a stop.
So did some testing by turning the roto-tiller manually with the engine off but the PTO engaged and was able to duplicate the noise.
So I ordered a PDF of the service manual for the tractor and sure enough, after some searching, found the section showing an over-running clutch inside the Mahindra transmission.
I've heard of over-running clutches in the external PTO driveline used on rotary mowers, for example, so that tractors with non-live PTO's would not be over driven while the PTO is coasting to a stop. An internal over-running clutch in the tractor, however, is a first for me and wondering what you guys might know about this and whether it is common especially in a hydrostat tractor.
www.tractordata.com
TractorData.com Mahindra 3015 tractor information
