Steel shooting target for rifles from retired 3-point scraper blade.
   / Steel shooting target for rifles from retired 3-point scraper blade. #1
jkk04
Gold Member
PLYMOUTH CA
John Deere 410 backhoe, MF 30 industrial tractor, IH TD-14 dozer, New Holland TZ24DA
AR500 steel is one of the more abrasion resistant steels and good for gun targets but quite expensive.
So, I decided to make a couple of steel targets by myself.
It came from a retired 3-point tractor scraper blade which is 1/2" thick AR450 metal as good as the AR500 (a little less strong).
If you have it, don't throw it away but make steel targets.
Ready to fun shooting.
Jkim
   / Steel shooting target for rifles from retired 3-point scraper blade. #2
I may be wrong but I thought welding weakens AR500. Also, the 1/2" AR500 targets I bought a few years back had minimum range of 200 yards for .223. .223 won't penetrate at 100 yards but will dimple which can result in ricochets
   / Steel shooting target for rifles from retired 3-point scraper blade. #3
Less than 100 yards I use Do-All Self-Healing targets. After that I have some old AR500 that has served me and my son for many years.
You are correct that the steel target could be weakening the steel on the welding area.
My understanding of the recommendation of 200 yards range for 223. .223 or 7.62x39 is for protecting from damage to the target, not for safety reasons.
I am not concerned about damaging the target because I made it with recycled steel anyway.😄😄😄
This morning I tested it at 100 yards with 7.62x39. It holds very well. (Small splatter bursts are 22 rifle and 2 of far-right side big bursts are 7.62x39)
Thanks for your comments
Jkk.
I might try it later.
The reason I prefer the paper target in 50 yards range is that I can see exactly where I hit.
Thanks
   / Steel shooting target for rifles from retired 3-point scraper blade. #6
I've read the warning labels on my AR500 targets, which are the same warnings as yours. That being said, I've shot my targets w/ .223, 5.56, and 7.62x39 w/i 50 yards and I've yet to dimple my targets. Mine are always hung on chains, so ricochets are directed down.
   / Steel shooting target for rifles from retired 3-point scraper blade. #7
Just curious about that -- why does hanging on chains direct ricochets down?
If it's because the impact swings the target, doesn't that swing start long after the bullet has bounced off? In terms of the brief times involved, I mean.
   / Steel shooting target for rifles from retired 3-point scraper blade. #8
Hang from chains welded about 1/3 or so down the backside so it hangs at an angle to deflect bullets downward.
Bruce
I made a target for the 22 rifle only this morning and hung it at 75 yards.
The pipe has scheduled 80 left over from the last project.
I am excited to hear a pipe organ bang sound when hit.🤣🤣🤣
Jkk
   / Steel shooting target for rifles from retired 3-point scraper blade. #10
Jkk
View attachment 763872 View attachment 763873 View attachment 763874
Interesting, my wife loves her wind chimes, may have to give something like that a try.
.22 is what I shoot more than any other round, 75 yards is currently my furthest distance. I plan to get some more clearing done this fall and get to a hundred. Most of my shooting is suppressed bolt action rifles.
Mike
2008 AAR MOBILITY SYSTEMS REFRIGERATOR CONTAINER (A54607)
2008 AAR MOBILITY...
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
UNUSED 70PCS White Metal Roof Panels (A53117)
UNUSED 70PCS White...
2011 Mack GU713 Granite Cooper TM-1882 18 Ton Crane Truck (A53422)
2011 Mack GU713...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
