Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #20,991
Ideal size of wood is not my concern. I need a mix of sizes and I like larger pieces to keep the fire going for hours when I am out or at night. Wood is not that expensive and a, say, 10% gain in "efficiency" is not as important to me as having a fire that works.
   / Tractors and wood! Show your pics #20,992
Some squirrel can say small pieces burn more efficiently
but I bet you the little pieces will burn up a lot faster than
you want because they do not last very long so the larger
chunks will burn longer and you don't need to get up in the
middle of the night to restock your stove!
Now the little pieces are great for a cook stove as you don't
have the space for the large chunks of wood
I wonder why so many guys say that you have to clean out
your stove pipes or chimney, as many years that I have burned
wood I never ever cheaned out a stove pipe or chimney and I
burned green pine sometimes.
willy
   / Tractors and wood! Show your pics #20,993
my furnace's user's manual says:
This is how it looks like
20 kW boiler + 2 T accu
Boiler controls T, O2 and CO2.
   / Tractors and wood! Show your pics #20,994
willy
When wood smoke goes up the chimney it contains a lot of wood product vapors. Creosote is one of them. If your chimney is hot enough all the way up through to the top the vapors stay as vapors and the chimney stays clean. Otherwise, on a cooler flue, the vapors condense as liquid on the flue lining and then the liquid turn to solid as it cools further. The water in wood turns to steam which at 212* cools the smoke so dry wood has hotter smoke and is better. Living in Texas it is easier to keep your flue hot compared to a place where the weather is much colder. So it is a combination of how seasoned your wood is, how hot you burn it, and how cold the chimney is that determines how fast your chimney gets dirty.
gg
   / Tractors and wood! Show your pics #20,995
Mine is from 2005.
By bowl do you mean the refractory tunnel?
I have replaced mine 3 times in 17 years
Yeah. I've replaced mine about the same. Rumor is they had a "bad batch" of them recently. I went probably 12+ years with the original and now it's every couple years. Sucks.
   / Tractors and wood! Show your pics #20,996
Started in on the 4th load of pulp. These are some ugly pines!
If you can get rid of that stuff and come close to breaking even it is well worth it in my book. My fir is a little different - on the outside they are pretty straight and a picture of health with good tops but they sure are ugly on the inside :giggle: Sort of like trying to make a silk purse from a sows ear. What's left in the woods rots quick because it has a good head start.
We are starting to get a little fall color now.
gg
   / Tractors and wood! Show your pics #20,997
gg
So are those pines???? Dont look anything like the pines I have.
   / Tractors and wood! Show your pics #20,998
No - what's left is puny fir - balsam fir. Even though you can't read it is good you can see a picture. :) Couldn't help myself.
Are you hunkered down or in a safe spot - if there is any...
gg
   / Tractors and wood! Show your pics #20,999
My scenario almost exactly, the first one went 11 years and I have had 2 more in the last 5 years
   / Tractors and wood! Show your pics #21,000
gg
Yeah, fruitcakesa started talking pines (didn't think his looked like pines either) and then you continued so I was wondering...
I am about 2 1/2 hours from the coast and "normally" by the time these storms get this far inland its usually just a windy rain event. At least in the 8 or so years I have been here. I think I am ready!! :LOL::LOL:
2008 ATOKA TRAILER & MFG. ATOKA TRAILER & MFG. (A53843)
2008 ATOKA TRAILER...
2012 John Deere 850K Crawler Tractor Dozer (A52377)
2012 John Deere...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
Case Maxxum 140 (A50120)
Case Maxxum 140...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
