The next guy that claims "green (or orange) paint doubles the price"
   / The next guy that claims "green (or orange) paint doubles the price" #281
Wow, my local shop told me they could source seals for any cylinder. They did and had it done in 4 days for $200.
Are you up early or late?
What the drawback to just replacing the OEM ones with less expensive ones? (in most cases I don't believe more money = more quality, but I do understand there is a certain amount of quality that comes at a premium).
   / The next guy that claims "green (or orange) paint doubles the price" #282
I was up late last night because I took a nap after dinner and wasn’t sleepy later. I really don’t know how aftermarket cylinders compare to OEM, but you would need to match the size of OEM exactly. And that might be a custom order. I do know as I said in an earlier post that most hydraulic shops can easily do a seal replacement job, and the local shop I used was quite reasonable; they even repainted it the correct color. They told me that they don’t source the expensive OEM seal kit; they just measure the size and type of seal and usually have something they can use on hand or can order them. No need to replace a cylinder just because seals leak; only if the cylinder itself is damaged.
   / The next guy that claims "green (or orange) paint doubles the price" #283
I've rebuilt several cylinders over the years. Hardest part can be getting them apart. Once you have removed the gland from the barrel it's pretty easy.
   / The next guy that claims "green (or orange) paint doubles the price" #284
My luck I would get it apart, then ruin one of the seals in the expensive replacement kit.
   / The next guy that claims "green (or orange) paint doubles the price" #285
I always worry about that as well. And some of the seals are very hard to get on the gland. You'll swear you are going to break them. But I never have.
   / The next guy that claims "green (or orange) paint doubles the price" #286
It happens. The local hydraulic shop replaces seals by size & has a selection. For rebuilding cylinders they have a huge old lathe - I don't know if it even runs, but it is perfect for holding cylinders, taking off the glands and pressing seals. I haven't been there in years now, but a decade ago the basic rebuild price for a 2" to 3" diameter cylinder was in the $100 to $200 dollar range.
That cost to rebuild makes sense - it takes an experienced guy an hour to do a cylinder right, the tools are basic, and the parts are standard inexpensive industrial pieces.
That's about all the info a mechanical guy needs to build a small repair business.
rScotty
   / The next guy that claims "green (or orange) paint doubles the price" #287
rScotty
Decent eye hand coordination, Good strong hands and wrists don't hurt either along with a nice hot container for hydraulic oil to keep them warm
ps. bought the fancy seal installer for the glands but have not tried them yet.
   / The next guy that claims "green (or orange) paint doubles the price" #288
The shop quoted me 3 hours for a cylinder rebuild.
   / The next guy that claims "green (or orange) paint doubles the price" #289
On a backhoe cylinder I spent 3-4 hours. Ended up heating the barrel to unscrew the gland...... :(
   / The next guy that claims "green (or orange) paint doubles the price" #290
If I can buy an exact sized replacement for less money than it costs to have a professional install a seal kit, I'm buying the replacement.
2018 Ram 5500 Bucket Truck 4x4 with Versalift VST40 - 45FT Rotating Bucket and Jib Winch (A52128)
2018 Ram 5500...
2016 Dodge Caravan (A50324)
2016 Dodge Caravan...
2018 John Deere 245G LC Excavator - Hydraulic Thumb, Tooth Bucket, 56K LB Class (A52128)
2018 John Deere...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
Kubota F3990 (A50322)
