So I have a TM1900 Caroni flail, I've had it 6 or 7 years. Seems to go through a lot of belts! I've been using Gates B43 Hi-power ll belts and getting ready to install a new set..again. So my questions are, does everyone use this belt or do you use another, and what tension do you set it at? I have the manual which (kind of) tells you how to do it but nowhere in the manual does it say what the tension/deflection should be. Also, has anyone used a banded belt on this and do you like it and how does it hold up? THANKS
Hello Hunt4570,
When you purchase your V belts you must make sure that all three V belts
have the same identical lot number meaning they were made with the same
batch of rubber and kevlar cord otherwise you will continue to have V belt
problems as they will not tension equally.
You also need to invest in a gates or goodyear V belt tension gauge to obtain
the correct V belt tension.
You can purchase a GATES RUBBER COMPANY V belt tension gauge from amazon
and tension one of the three v belts and all three of them will have the same
tension AS LONG AS THEY HAVE THE SAME LOT NUMBER.
When you visit the parts store you have to be sure to tell the clerk all
three V belts MUST HAVE THE SAME LOT NUMBER.
You could purchase a 3 band V B-43 belt but it would be $500.00-$700.00
depending on which brand you buy.
Its less expensive to buy the correct V-belts with the identical lot number and a
Gates Rubber Company V-belt tension gauge from amazon.
