Major water leak Massey 165
   / Major water leak Massey 165 #1
Mike from Texas
165 Massey Fergusion
I have had this Massey Fergusen 165 tractor for almost 20 years (bought from a tractor master) and never had any major problems. It was featured on the back cover of Farm and Ranch Living magazine, titled - Red, White and True, June/July 2016.
Stuck gears and some busted hoses have been my only issues - nothing more. Last week when I ran it to do some shredding, I noticed it started leaking water. I did not find any hose is broken or radiator leaks. The leak is coming from the top of the engine from what looks like the valve cover. (?) Today I tried copper/glass sealant in the radiator but no luck. This has become worse than it was when I first noticed it. I tried to include a video but that is not working as it is a format or size problem. We did have a bad freeze here in Texas a couple of months back. Maybe that caused this, but the leak is in an odd place looking like it is coming from the valve cover gasket.
I can send a video if you can email me. But it will not let me attach it here. The leak does not look low enough to be a head gasket. Any thoughts/help would be appreciated.
   / Major water leak Massey 165 #2
Sounds like a cracked head ? Was there plenty of antifreeze in it?
Thanks for the quick reply.
There was antifreeze but maybe not enough. I guess I will need to tear it down to see where it is cracked. Then try to get parts. I assume that much water coming out means the stop-leak products would not do me any good. Thoughts?
   / Major water leak Massey 165 #4
Oh yeah, with that much leakage stop-leak is not going to work. You might want to pull the valve cover and buy or borrow a radiator pressure testing kit. Most full-service tractor repair shops (and many auto shops too) have radiator pressure test kits with a variety of adapters for various size radiator cap holes. I bought a kit last year myself (around $50 on Amazon). By using that pump in the kit you can pressurize the coolant system and with the valve cover off you should be able to see exactly where the water is coming out without pulling the head. That will tell you what problem you have.
I will do that and go from there. I see what you mean - on Amazon. It will be a couple of weeks before I can get back to it (have a day for the tear-apart time). I will let you know how it goes. I appreciate the feedback/tips. Have a good weekend. Thanks again.
  • Good Post
Reactions: JWR
   / Major water leak Massey 165 #8
Check your oil level too. If it is overfilled, there may be water going into the crankcase.
It did not look full but there are what look like water beads on the stick, so I believe there is water in there too. I will be digging into it soon and deciding where to do from there. Expecting the worst and will be surprised if it good news as this plays out.
   / Major water leak Massey 165 #10
If there is water in your crankcase, pulling your drain plug will show it as the water will be the first liquid to come out.
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
2025 CFG Industrial JDCPF48-4400-FF Pallet Fork and Frame Attachment (A49462)
2025 CFG...
1997 GROVE TMS750B 50 TON CRANE (A51222)
1997 GROVE TMS750B...
