Great topic…I’ve been a ball bearing engineer for over 36 yrs. Here’s a bearing guys perspective and sorry for the long post, but ask an engineer what time it is and they tell you how to build the clock….,
Basically, all greases are not compatible. I avoid EP Moly based grease in a rolling element bearing. I have seen many bearings ordered from the factory only to see the OEM call out an incompatible grease , different grease for maintenance. Lithium complex greases tolerate water intrusion better than clay based greases. Not all synthetic oil base greases are compatible with mineral oil base.
If it’s sealed, the bearing was designed with a specific clearance, load-speed capacity, installation fit, grease fill percentage of the internal cavity void, for the very reason many have referenced on the seals blowing out, but percent fill of lube is really controlled to maintain the film thickness between the rolling elements permitting minimal heating of the grease in shear flow…..a ball or roller bearing is only suppose to run on a film or lube and it acts lube an oil pump internally, never touching metal on metal…..I’ll stop here.
  A sealed maintenance free bearing really shouldn’t use a clay based grease.  A relube bearing is more costly, and has special seals and lube passages, but these are mainly on the sliding bearings, spherical plain bearings (ball joints, tie rods, journals).
Injecting grease in a failing rolling element bearing with a needle could work, but it probably is failing by that point. If it made noise, it’s failing.
Spindle bearings are specially designed for relube and are damaged if done incorrectly, wrong grease, over pressured, etc.
if a bearing is designed for relube, it will always outlast a sealed maintenance free, if maintained. Those special holes and lube grooves are not expensive to machine, but all the cost is in the debur operation in manufacture and OEMs don’t like the added cost. Depending on the bearing, load and speed, rubber seals may not survive and hence the steel shields/slingers, which don’t work well in wet-muddy areas. The designer had to make a trade off, load capacity for long life.
Bearings are designed to wear out, keeps me employed, but I hate nothing  than a bearing failure on my personal equipment and the needle injection is my last ditch effort to buy time, waiting for the replacement.
