Transmission help needed for 1967 Ford 4110 LCG with 201ci gas.
   / Transmission help needed for 1967 Ford 4110 LCG with 201ci gas. #1
4110LCG
Twinfalls Idaho
ford 4110 LCG
Hello, I have a 1967 Ford 4110 LCG with the gas 201ci engine and it originally was built with the SOS transmission. Somewhere between 1967 and 2005 someone installed a different transmission into it. The new transmission has a HI/LO option and 3 forward gears if you shift up and one reverse gear if you pull down on the shifter straight down towards the seat. I cant find this shift pattern anywhere. Could I be missing another reverse gear down and left???? The transmission has C7NN 7006AR stamped on the side. I am going to rebuild the engine and install a new clutch at the same time but I have no Idea what transmission I have. Any advice would be amazing!
   / Transmission help needed for 1967 Ford 4110 LCG with 201ci gas. #2
Do you have a dog leg shifter on the left side of the tractor that you change ranges with?
Yes it has two sticks. One gear shift and second is HI/LO
   / Transmission help needed for 1967 Ford 4110 LCG with 201ci gas. #4
Are the numbers on the side of the transmission any help in positively identifying the model of transmission? I searched them online and couldn't find a cross reference anywhere.
If I am pulling my ripper in hard clay and need slow and low, I put the tractor in Low range and shift straight up the middle to what I though was 1st??? If I shift up and left its to fast.
Its almost like its a 4x4 not a 6. I am at a loss.
I found this after searching for hours on the internet and my low gear up the middle makes sense after finding this.
   / Transmission help needed for 1967 Ford 4110 LCG with 201ci gas. #10
It is a 6x4 transmission and you should be able to find the other R, unless the shifter is jammed. BTW, the number you gave is a casting number and won't tell anything except the basic year it was designed.
Look on the transmission bell housing for the true model number, the serial number and the date code. The true model number identifies what transmission it is, but I think you have done that already.
2023 JOHN DEERE 6R 145 LOT NUMBER 263 (A53084)
2023 JOHN DEERE 6R...
2015 Ford F-450 Service Truck, VIN # 1FDUF4GT7FEC15731 (A51572)
2015 Ford F-450...
2025 New/Unused 72in Wolverine Grapple Bucket (A51573)
2025 New/Unused...
INOP/NON-RUNNING 2007 Peterbilt 378 Flatbed Mud Mixer Truck, VIN # 1XPFDT9X37D666626 (A51572)
INOP/NON-RUNNING...
2000 Toyota Tacoma 4x4 Pickup Truck, VIN # 5TEWN72N6YZ690085 (A51572)
2000 Toyota Tacoma...
2003 TRAIL KING TI-BROOK AFRM 40 - 40' DUMP TRL (A51406)
2003 TRAIL KING...
