Cultivating Sweet Corn With an X530?
   / Cultivating Sweet Corn With an X530? #2
Thanks for the post. I have been thinking about buying a cultivator for my JD X500.
   / Cultivating Sweet Corn With an X530? #3
Just curious why you wouldn't be using the 140? 140s are the best one row cultivating tractor that was ever made. I have 3 of them.
   / Cultivating Sweet Corn With an X530? #4
Apparently, you never cultivated with an Allis Chalmers G, I have a 140 and a G, the G wins, no contest.
SR
   / Cultivating Sweet Corn With an X530? #5
You're correct. You win. I've never run a G. I've never seen a G. After looking at it I will stick with the offset 140s. As I said I've never seen one but that looks to be a wider tractor for a 2 row operation. If it won't plant on 4 foot rows that's an automatic out for me.
   / Cultivating Sweet Corn With an X530? #6
The G was intended for 1 row applications, but it's so adjustable it can be made for 2 row, and/or any spacing.
Every tool you can think of for small scale, was made for the G, but cultivating was/is it's forte. Once you've seen one with all its options, you will be amazed!
The 140 is a bigger/heavier tractor, over a G
SR
   / Cultivating Sweet Corn With an X530? #7
The one I saw with a planter was a 2 row. I don't know if the G had a PTO but the 140 PTO was very useful. I run a rotary hoe on mine that works very well. I'm also a fan of the ease of use of the fast hitch and the speed that implements can be changed. It also has a really nice fertilizer distributor setup.
   / Cultivating Sweet Corn With an X530? #8
A G can be adjusted for width and length. Yes, the 140 is a handy tractor, as I already said, I have one, BUT this was about "cultivating", and there's no better one row tractor for cultivating than an Allis Chalmers G.
I have, also the Cub, but my brother gave me the cultivators and I thought it would be fun to try out
2015 INTERNATIONAL LF687 (A53843)
2015 INTERNATIONAL...
205028 (A52706)
205028 (A52706)
2005 V.E. ENTERISES 130 BBL STEEL VACUUM TRAILER (A53843)
2005 V.E...
PALLET OF SCAFFOLDING (APPROX. 18 PC) (A52706)
PALLET OF...
3 Pallets Oil / Chemical Sock Boom (A53117)
3 Pallets Oil /...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
