Midwest Gasoline to Spike $0.50-$1.00 Per gallon
   / Midwest Gasoline to Spike $0.50-$1.00 Per gallon #51
Another ‘non-web source’
Financial Intelligence by Karen Berman & Joe Knight
   / Midwest Gasoline to Spike $0.50-$1.00 Per gallon #52
Your chart.
12/2021 - $70
6/2022 - $123
3/2023 - $70
There was a 75% increase in value between 12/2021 & 6/2022
There was a 43% decrease in value between 6/2022 and 2/2023
If we are discussing percent change over time for a value. This is how it works.
If it was 50% decrease in value from 6/2022 to 3/2023 would have bee 61.50, 75% decrease in value 30.8, 100% decrease in value 0.
… the order of the values in the numerator doesn’t matter much, the correct denominator value is what is important, original/first value always goes in the denominator, provided you can figure out a negative number…
I don’t have any base math texts from grade school for a pure percent change formula that isn’t ‘from the web’, but here is a percent change snippet from Mechanics of Materials by RC Hibbeler from an entry level engineering class.
Not sure what you are trying to prove with this:
70 * 1.43 = 100.10
70* 1.75 = 122.5
70 with a 75% increase is indeed the same as 12/2021 to 6/2022.
(123-70)/70 * 100% = ~75%
Your proof however doesn’t reflect percent change.
See, in post 40 I defined what I was calculating, which is the last cycle of peak to trough.
Then you come along and have to redefine what I was calculating to make your point of: Trough to peak, to trough again.
You change the goal posts.
All that *100 at the end does is move a decimal point over by 2. However I express the solution in a %, which does the *100 automatically. I know that .75 expressed as a % is 75%. See post 40 again to see my solution is in a %.
Your not going to get me in a game of gotcha with math. I'm an Actuary, I do math all day every day for a living.
   / Midwest Gasoline to Spike $0.50-$1.00 Per gallon #53
Here's the things most of us see....
$123 high
$70 low
That's a difference of $53
$53 is about 43% of $123
Most of us see a 50% price decline from $123 as leaving it at $61.50.
A 75% price decline from $123 would be leaving it at $30.75.
Without slinging insults, is there a different way of explaining it to come up with another answer?
   / Midwest Gasoline to Spike $0.50-$1.00 Per gallon #54
$123 high
$70 low
see post 43.
   / Midwest Gasoline to Spike $0.50-$1.00 Per gallon #55
see post 43.
I did. We all did. None of us understand what you're trying to convey there.
Haven't seen one person get the lightbulb turned on and say "Ah, now I get it."
Most of us believe if something costs a dollar, and then it costs 50 cents, that's a 50% price drop.
If something costs $123, and then it costs $70, that's a 43% price drop.
   / Midwest Gasoline to Spike $0.50-$1.00 Per gallon #56
Glad you figured out decimals to percentage as an Actuary.
“So if we take the peak of 123 and the low of 70, which was March of 22-March of 23 that is a 75% decline of price.”
The goal posts you set above.
Time and values.
$123 - March 22
$70 - March 23
I added the other through to peak for clarity of point on calculations.
   / Midwest Gasoline to Spike $0.50-$1.00 Per gallon #57
Moss...you've always been a reflexive contrarian.
If you understood post 43...I mean really understood it. You would have your ah ha moment. But again, contrarian.
It dropped by 75%. I don't know how else I can make you understand that.
   / Midwest Gasoline to Spike $0.50-$1.00 Per gallon #58
Time and values.
$123 - March 22
$70 - March 23
I'm glad you finally figured out all my solutions were in the proper percentages already.
Good job.
   / Midwest Gasoline to Spike $0.50-$1.00 Per gallon #59
I don't understand post 43, that's why I'm asking.
   / Midwest Gasoline to Spike $0.50-$1.00 Per gallon #60
One more time...
If something goes from 123 to 70, how is that expressed in as a % change?
Well...
(123-70)/70 = 75% (I already did the x100 to express as a % for mr. bnold's hang-up). The price went down 75%.
We can check that number to make sure. To check you can do it two ways:
From the starting point of 70: 70*1.75 = 123
From the ending point of 123: 123/1.75 = 70
I hope you can see the multiplicative relationship here. It dosen't matter where starting point is, the relative ratio works either way. I explained earlier how to add (multiply) and subtract (divide) to keep the % change a constant ratio between two points.
I really have no other idea how to make you understand.
(3) 12" X 30# X 14' (1) 12" X 30# X 120.5" (A57192)
(3) 12" X 30# X...
2013 BMW X5 xDrive50i AWD SUV (A56859)
2013 BMW X5...
2018  FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52576)
2018 FREIGHTLINER...
UNUSED WOLVERINE SBG-13 72W 83.2" SLIDING (A57193)
UNUSED WOLVERINE...
2014 Ford Transit Connect Cargo Van (A54814)
2014 Ford Transit...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2016 Peterbilt 320...
