Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #22,322
SR, I wonder if your tractor wheels will like the wire baskets better.
gg
   / Tractors and wood! Show your pics #22,323
This works very well, so one problem solved!
SR
Creative solution!!
   / Tractors and wood! Show your pics #22,324
I must have missed a good reason to not to put the forks directly under the tote. If "One of the biggest reasons is, having to close the pallet forks a bit to move them" is an issue, I would question the forks. Stacking totes farther apart does not make sense to me.
   / Tractors and wood! Show your pics #22,325
I must have missed a good reason to not to put the forks directly under the tote. If moving the forks side to side is hard, I would question the forks. Stacking totes farther apart does not make sense to me.
That's what I was wondering too ???
gg
   / Tractors and wood! Show your pics #22,326
I have a makeshift 3pt fork system on my loader until I get the time to weld up a quick attach setup. I know that it is not easy to drive the forks under the very bottom of the totes plus it digs up the ground. His forks are too wide to fit in the available slots in the bottom of the totes. His forks/ grapple were purchased well before the totes, never having the intended purpose to use these totes. I'm sure he wants them typically set at the widest setting for stability on his main activity of picking up logs. So if it's a pain to adjust for the seldom used metal tote, then a solution to adapt was developed. He really likes his wood totes that carry more, are built to his specs, easily made due to him having a BSM. He also seems to have plenty of flat area to store these totes with the logs sticking out, so I see no downside to his solution. I also feel what works for the few, doesn't mean it has to be for the many. Same reason I hate Congress...
   / Tractors and wood! Show your pics #22,327
If the wood in the totes is green, staking them a bit further apart is a good idea. It helps improve air circulation
   / Tractors and wood! Show your pics #22,328
He stores them in an open field so space really doesn’t matter. Even if the forks slide freely which they never do having to get off and move them is annoying.
   / Tractors and wood! Show your pics #22,329
gg
I don't think the baskets or boxes have that much to do with the wheels, they just aren't that heavy, but I bet having logs stick waaay out to the side does.
No problem, it's easy and fairly cheeeep to make them stronger.
SR
   / Tractors and wood! Show your pics #22,330
Could you please show me a quote where I complained that it was too hard to move the forks in or out.
IF, you understood the part about drying splits, THEN it would make sense to you.
SR
2016 FREIGHTLINER CASCADIA (A55745)
2016 FREIGHTLINER...
2008 Ford F-450 Service Truck (A53422)
2008 Ford F-450...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A53421)
2023 Caterpillar...
2012 Club Car Precedent Electric Golf Cart (A53424)
2012 Club Car...
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
2014 MGB BLENDER (A55745)
2014 MGB BLENDER...
