oldrustysteel
Gold Member
- Joined
- Dec 4, 2023
- Messages
- 440
- Location
- Southwest Ohio
- Tractor
- Ford 850 Ford 8n Kubota B6100 AGT L12 Baby Excavator many other toys
I put in a new ignition switch and wired the lights and hour meter so if the keyswitch is off everything is off. I removed the red battery disconnect switch because it is not really necessary, and I've heard they are not water proof. I will probably install a cupholder where the switch was. I am now up to 13 hours and still like the machine. I also installed a temp gauge and tachometer, clock, hourmeter all in one neat little package. works good so far. I like being able to monitor the engine temperature. then I cleared some trees off the trail and cut up some of the wood. what did you do to or with your little digger? For anyone planning to work on the china digger,, remember they dont always follow wire color-codes like we do in the USA. I found Hot wires that are Green, and another black wire with a white stripe that is hot.. Don't assume anything when working on these little guys.. I made some reminder notes for the next guy who has to do anything on this AGT L12.
