WM75Guy
Elite Member
We are in good shape so far. Problem will be when everybody wakes up and gets ready for work tomorrow morning. If we could just get the sun to shine at night.
Cold temps in Texas and ERCOT is asking everyone to conserve electricity for two mornings. Monday and Tuesday morning between 6:00am and 10:00am are times they are asking you not to use electricity.
ERCOT Expects Tight Grid Conditions, Requests Conservation Monday, January 15, from 6 a.m. to 10 a.m. CT
ERCOT Expects Tight Grid Conditions, Requests Conservation Monday, January 15, from 6 a.m. to 10 a.m. CTwww.ercot.com
ERCOT ends appeal, Atmos continues to ask North Texans to conserve as bitter cold continues
ERCOT had requested that electricity use be preserved from 6 a.m. – 10 a.m. Monday. Atmos also asked customers to conserve natural gas.www.cbsnews.com
Situations like this need to be resolved to go all electric (no Fossil fuels).
I have nothing useful to contribute here, except to say that every time I see "Helogabals", I wonder if it's Latvian for "huge balls".Drive an EV in the cold, for real, as @Helogabals apparently does.
Actually few moons back, when I signed-up in at TBN, just before it I have read an article about Roman emperors. There was that man HeliogabalusI have nothing useful to contribute here, except to say that every time I see "Helogabals", I wonder if it's Latvian for "huge balls".
Same as the Ford Lightning… if you are actually using it for work, you won’t be for long. I see it as an electric AWD EV. Not really a useful load truck. It’s a truck, for people in the suburbs, who want to own a “truck”Another somewhat contentious TeslaMotorsClub thread
Cybertruck. Towing with a Tesla car on a trailer.
Have to say even worse than what I expected.
87 Miles. (100-3% range is 115 miles) Charging to 100% every time will degrade the battery.
Towing heavy any real distance with an electric Pick Up is not competitive with a diesel or efficient powerful gas Pickup without a large capacity battery like a 200kwh battery which means carrying a lot of weight and longer charge times.
I am sure a CT is fine for unloaded driving and local towing travel, just not so sure towing heavy long distance is "there" yet..
Amen. I got home at 1am from NYC the other day. Got to my car, sitting in the cold for three days. Started fine, but the door latch was so cold it was sticky and would not latch. I drove 40 miles home on I70 with the door open. Next week it will be 40F again.The interesting thing is because the Lightning is shaped like a regular flat nosed truck and is less aero dynamic than the CT it does a better job at breaking the wind front that actually hits the tall trailers and sees less of a range loss while towing.
We got a call from FIL and some pipes may have frozen, so we needed to go crawl under the house to make sure no water was leaking.
Had not planned to go anywhere so the diesel trucks were not plugged in to block heaters. I decided to see and Neither RAM would start. Then opened the ap on the MY which was outside. Interior temp showed -17*F. Turned on the Defrost mode and 10 minutes later we left. Car used almost 2.2KWH for a 2 mile round trip. But it ran, and was a comfortable warm ride and no real waiting to leave. Luckily no broken pipes but had a loose vent cover that needed screwed down tighter to seal up the air leak and a milk house heater added to heat things back up. On call. Oh and a tractor related item the FIL's Yanmar 2310D starter is being finicky even with a block heater and using a space heater to get it up and running
Trucks are on battery chargers and will plug in the block heater.
Will be Glad when this cold front leaves...
