Need new Joystick
   / Need new Joystick
I saw a combined unit at Vevor. Is it worth a shot? But on my second 2400H its valve has the capabilities on the decal. Would Vevor’s do this?
   / Need new Joystick #12
The Vevor valve should do everything your current valve does. Check the specs for "Float", but if it is for a loader situation, then it does. Vevor products are very inexpensive Chinese products. From what I have experienced, they perform as expected, but don't expect to get parts is needed.
Also, you probably have to change your plumbing to accommodate the Vevor valve.
   / Need new Joystick
If you had to replace your loader valve do you have a preference?
   / Need new Joystick #14
If you end up going with a new valve, make sure you get the correct power beyond sleeve for that valve you get.
   / Need new Joystick
I don't have a Branson, but have you looked at Surplus Center?
I believe this is what I need. I wonder if it is vastly better than a cheapie from Vevor?
   / Need new Joystick #16
May be the same valve, but that will work.
   / Need new Joystick
Sorry for the delay. I did purchase a rocker plate and am thinking of buying cables too, before I go the whole joystick route. I am not at the tractor's location, but are there "stand-sized" cables as I cann ot find specs on the length of the ones I have.
If all that fails, I would go the combined JS/valve and deal with new hoses as they are weathered. The Surplus unit looks good. No idea about thread compatibility. Any other suggestions? I will call Scott, the Service Director in Rome, Atlanta, but he can be hard to get a hold of.
By the way, does anyone know if a Peruzzo Flail mower will fit a Harbor Freight quick attach?
Thank you
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
2011 Ford F-350 Knapheide Service Truck (A54814)
2011 Ford F-350...
10 FT Poly Bunk Feeder (A55218)
10 FT Poly Bunk...
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
2015 Chevrolet Express 4500 Shuttle Bus (A53422)
2015 Chevrolet...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
