Just finished my 40th hay harvest
   / Just finished my 40th hay harvest #1
zzvyb6
Super Member
michigan
jd 1070
Most of those years were behind a 35 hp JD tractor, a NH 479 haybine, a JD 55 rake, and a JD14T baler. A few thousand a year from local fields including my own. A few years ago I added a NH1012 stack wagon because now I'm doing it by myself.
Then a customer teased me into trying out her Vicon 1210 round baler. It was a lot of trouble caused by worn parts, a peculiar tie wrapping system, and it's fixed chamber design. And, quite frankly, the 5x6 bales were a bit much for my tractor, considering that I could never figure out how to gauge when the bale was done.
Looking around, I found a 35 year old JD 335 variable chamber baler in good condition and went thru it to check it's features: 4x4 bale size, twin-tie (faster wrapping), bale size and bale symmetry indicators, signal tone.
It only needed some chains tightened and 4 pickup tine sections. Operators manual free on-line from Deere. What a difference.
I had no trouble at all with starting a bale roll, reading size progress, listening for the tone at full capacity. My 35 h.p. 20250912_190726.jpgtractor never lost any rpm during travel in 2nd range 3rd gear the entire time. Nice bales all over 800 lbs (I measured most of them out of curiosity). Heavier than the Vicon's bigger sized ones. I never had to leave the tractor seat the whole time.20250913_175824.jpg20250830_132914.jpg20250831_190410.jpg20250901_190353.jpg20250910_183535.jpg20250917_182423.jpg20250917_183415.jpg20250917_183807.jpg
   / Just finished my 40th hay harvest #2
Great post!
In the mid to late 70s I would request time off from my part time after school job to bale hay for a local dairy farmer. It was satisfying work to spend the days putting up hay. 40 years of it must feel like a wonderful accomplishment. Congrats!
   / Just finished my 40th hay harvest #3
Congrats! I’m in my 20th and hoping to break 1,000 tons of hay this year.
   / Just finished my 40th hay harvest #4
Congratulations
In 2023 I completed 35 yrs of custom hay baling & decided to retire due to lack of help. My physical disabilities of permanent nerve damage hadn't got any better with aging!!!
Do you happen to know moisture % of that hay being round baled? I'm surprised a JD 335 will make a 4X4 rd bale that weighs 857#s that would be below 17% moisture. Last rd bales I weighed from my JD 467 rd baler were 4X64'' & only averaged a little over 1000# @ 15% moisture
2012 Peterbilt 382 T/A Day Cab Truck Tractor (A55788)
2012 Peterbilt 382...
UNUSED DIGGIT 6' HIGH FENCING - 1 ROLL (A54757)
UNUSED DIGGIT 6'...
2004 Ford F-550 Mason Dump Truck (A55788)
2004 Ford F-550...
2005 Ford F-650 2,000 Gallon Water Truck (A53422)
2005 Ford F-650...
Towable Message Board (A55787)
Towable Message...
UNUSED (2) 7000# DROP AXLES W/ BRAKES (A54756)
UNUSED (2) 7000#...
