Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #25,521
Helped the neighbor with a little wood today. But it was just to hot. I only lasted a couple of hrs.
   / Tractors and wood! Show your pics #25,522
My daughter picked what part of the log she wanted for the bench, and I cut to length. Then sanded with 80 grit, then 150, then 220.
Drilled the holes to mount them to the bench frames. Then it was time for the epoxy, I painted on a decent coat, maybe 1/8" or so, and let it sit to cure.
Then loaded them up to take to the camp.
Despite the epoxy sitting and feeling only slightly tacky, it was not fully cured, so I got some dull spots where any pressure was applied, aka fingerprints etc. Oh well, it had to be done on Sunday, so I just couldn't let it sit any longer. Here's the final product in its "Bus stop" type alcove. Epoxied rebar into bench legs & the concrete floor. The brackets are recycled plastic and about 30lbs each.
   / Tractors and wood! Show your pics #25,523
That looks "really" nice!! Good job!!
   / Tractors and wood! Show your pics #25,525
Looks great. West System epoxy? Think the mix ratio was off, or just not mixed thoroughly? Odd for it to not cure after a few hours, especially at 1/8" thickness (thicker cures faster).
   / Tractors and wood! Show your pics #25,526
TotalBoat Tabletop Epoxy, which is meant to pour up to 1/2" thick. Cure time should be 12 hours, however it was into the upper 50's at night which will slow the curing time. By the time we were packing up & taking photos, it felt pretty much set, didn't risk sitting on it yet though, thats the last thing I need, my denim ass print forever in the bench!!
The mix was pretty dead on, I left the brush in the epoxy to help remove the epoxy from the bucket. However this happened instead....
   / Tractors and wood! Show your pics #25,527
Thanks Winter
   / Tractors and wood! Show your pics #25,528
Nice...very nice job done. (y)
   / Tractors and wood! Show your pics #25,530
That turned out to be some beautiful slabs! Nice!
New Holland LX665 (A53314)
New Holland LX665...
2017 Ford F-150 Crew Cab Pickup Truck with Liftgate (A55852)
2017 Ford F-150...
2015 Nissan Altima Sedan (A55853)
2015 Nissan Altima...
2005 Woodchuck Chipper (NOT RUNNING) (A50775)
2005 Woodchuck...
SHOP BUILT FLARE STACK (A53843)
SHOP BUILT FLARE...
GALAXY - SET OF 19.5L-24 INDUSTRIAL R4 TIRES (50% TREAD) (A55301)
GALAXY - SET OF...
