LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 13,975
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
From the Vt inspection manual;I believe that in VT your vehicle will not pass State Inspection if the tires are more than 10 years old.
VN-113 - Periodic Inspection Manual
VN-113 12/2019 MTC 31
PLEASURE CAR AND LIGHT TRUCK
INSPECTION STICKER PLACEMENT
Inspection stickers must be affixed to a vehicle’s windshield in a location specified by the commissioner of the DMV.
WHEELS AND TIRES
Procedure: Examine tires.
Reject vehicle if:
1. Any tire is worn so that less than 2/32-inch tread remains in any two major grooves.
2. Any tire has a worn spot that exposes the cord through the tread.
3. Any tire has visible bumps, bulges, or knots indicating failure or separation of the tire structure.
4. Any tire has cuts, snags, or severe ozone or weather cracks in any location.
5. Tires on the same axle are not the same type, construction, or size.
6. Any tire is marked "For Farm Use Only," "Off-Highway Use Only," "Racing use Only," etc.
Advise customer if:
1. Tire tread depths are between 2/32 and 4/32 of an inch, as they are likely to diminish to below safety standards before the term of the safety inspection expires.
2. Tire size does not match manufacturer specifications.
3. The tire is more than 8 years old. In this case, recommend replacement.
Note: Refer to the National Highway Traffic Safety Administration (NHTSA) for tire manufacturers’ recommend tire age for replacement.
Procedure: Examine wheels. Refer to 49 CFR § 570.10 for additional information.
