Battery Replacement for XJ 2025H
   / Battery Replacement for XJ 2025H #1
yooperdave
Marinette, WI
Tool Cat 5600, LS XJ2025H, Branson 4215HC
Tractor is around 6 years old. Battery still works, but now has some attitude while cranking the engine over at 60 degrees outside.
I decided to remove and replace the old battery for new now while the weather is still favorable. I have changed numerous batteries on numerous machines in the past. This one really takes the cake. The battery is located in a pit with steel framing and other items over it. Being blessed with large hands did not help accessing some of the bolts. After an hour of removing the steel, I now exposed the battery. Hoping to pull the battery tomorrow. So thankful I never needed to charge the battery in the past, as the battery is not accessible. Can't wait to replace with something able to last another 6+ years. A set it and forget it game plan.
Yooper Dave
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
1991 International 4900 Box Truck (A55315)
1991 International...
2018 Dodge Grand Caravan SXT Van (A53424)
2018 Dodge Grand...
UNUSED FUTURE HYD AUGER SET (A57193)
UNUSED FUTURE HYD...
2017 Caterpillar 326FL Hydraulic Excavator (A53421)
2017 Caterpillar...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
