Flail Mower Need advice on right cutting attachment
   / Need advice on right cutting attachment
Good evening farmingthefarm,
In order to deal with that bush land you need flail shredder.
With 3.24 Hectares to deal with and with your bobcats horsepower
you will be limited to a 48 inch/122 centimeters /1.22 meters width
of cut to mow and not overload the tractor.
To manage this you need a flail shredder with a 4 row flail mower
rotor with side slicer knives to create a fine clipping that will dissolve
into the soil quickly and reduce the fire risk by reducing the fuel load
to just the bush sod after a few mowings.
I want to help you with this so you have a forever flail mower that you will
be able to use for a very long time and have bush land that will be easy to
manage with mowing and reduce the fire risk to a minimal amount.
Please take the time to tell us what brands of flail mowers the tractor dealers
in your state are selling so I can help you pick the right one.
When it is convenient for you I would like you to visit youtube and type in
"tractor time with tim" and look for his flail mower videos to see him mowing
using a John Deere sub compact tractor with a flail mower. He is not mowing
bush land but you will see the quality of cut that it will provide you.
Leon
Thanks Leon,
I've been chatting to others and seeing what's best and I'm leaning towards this Woods slasher, best part is that it doesn't leave a windrow!!
   / Need advice on right cutting attachment #32
The long cuttings will still be there even though the
anti-discharge chains prevent objects being thrown.
If at all possible, please hire the first brush mowing
done, and then decide if you want that type of mower.
I do not think you will because of the long brush that
it leaves on the ground and the long brush will kill the
brush under it and it will not dissolve quickly into the soil.
You also must remember that only half of the cutting edge
of the slasher will be used to cut brush with every rotation
of the spindle where the full width of a flail mower with side
slicer knives is cutting everything in its path at 2,200+
revolutions per minute providing you with a fine mulch that
will dissolve into the soil more quickly when it rains or dries
to a fine particle over time.
The flail mower with side slicer knives will let you recut the
brush on the first pass if you travel slowly enough and recut
it a second time if you mow in a spiral pattern from the center
of the hectare as mowing in a spiral overlap saves you time by
avoiding braking and backing up and turning around.
Mowing small or large acreage is incredibly boring and if you have
a fender radio and ear plug's for hearing protection or radio earmuffs
all the better.
   / Need advice on right cutting attachment #33
Hello Farmingthefarm,
Before you sit down with a salesperson you need
to decide whether to ask them one question;
"Are you willing to lose a sale and not a customer"
If they hesitate, blink their eyes, reach for thier coffee,
or start swiveling in their chair, walk away.
If they say:
Yes,
it is because we want you as a customer for life;
and we want you to have the right implement for your
needs.
it will be safe to open your check book or ask for
a 30 day quote to have a bank draft typed out and mailed
to them.
Print this out, take it with you, lay it on their desk so they can
read it and react accordingly.
   / Need advice on right cutting attachment #34
I have not found this to be true ... Look at my pictures again that I posted above ...
Here is more of my experience ... Farmer who was haying my field, couldn't get in between where I had planted some trees ... So I cut it with my brush hog last summer ...
This is very heavy thick and tall !
Looked like this about 2 months ago ...
Looking the other direction, camera mounted in the peak of my house just taken ... Area in question is just past the barb wire fence ...
How about a different approach for the OP, instead of BUYING, see if there is a rental place, that has different cutters to rent, even if they have one "too big" for your current tractor, if it is a "type" your interested in, it might be more prudent to rent a tractor and cutter for a day, and "try it" ... In Missouri we have a saying ... "Show-Me!" Mow part of the property with one type, then the other half with the other ... If possible than mow them both again, with the other mowers ... As in now the North part with a slasher/brush hog, now the South part with the flail ... See, and take pictures to compare (I'd love to see them :) ) then mow the North part again, but with the flail, and vice versa with the slasher on the South Lot ... Then buy what your happy for on your property.
Due to my job as a long distance truck driver, I'm gone a lot and only home for a day or two a month ... I don't have time to mess around with renting ...
I bought my last mower, a finish mower, even though originally I had my heart and mind set on a flail ... However from all my reading, I ended up choosing a finish mower, due to two things that seemed like I would be flirting with disaster, or at least disappointment If I bought a flail ... Most all my reading pointed to flails doing best in the 2"-4" cutting height, I wanted to cut at 5"-5.5", they also seemed to work best at ground speeds under 3 mph ... I want to mow in the 5-6 mph range ... Combine those two factors, and I bought a finish mower, I already have a brush hog.
   / Need advice on right cutting attachment #35
The Australian bush land is entirely different than what we have to deal
with in North America as they have a year round wildfire fire risk.
The less fuel he leaves to burn by mowing and maintaining a 2 inch
height of sod brush in the wet seasons the safer it will be for the
landowner as there is much less available brush as a fuel source.
   / Need advice on right cutting attachment #36
Guess you haven't lived in AZ ... I did for 13 years ... I use what works ... Cut brush or grass compost.
I see you changed the parameters ... Brush hogs leave too much debris on ground which will kill it, now it's a wild fire danger ... A flail may pulverize it more, but it still needs to break down into a mulch/compost which takes time ... OP doesn't seem interested in mowing every week ...
   / Need advice on right cutting attachment #37
A rotary cutter/bush hog Will work; a flail mower Might work, and it Might work better; but i dont think anyone will tell you the rotary cutter won't work. Just my opinion
   / Need advice on right cutting attachment #38
In regards to the fire danger elimination, or at least reduction ... Cutting twice or more a year will provide fresh new growth, which is not really all that flammable ...
Depending on width of mower, and ground speed, you should be in the 1-2 acres an hour range ... So a afternoon of "tractor time" ... A few times a year ...
   / Need advice on right cutting attachment #39
Like this ... Neighbor to my South brush hogged his side last fall ... He puts his cattle in there occasionally, they eat what they want/can ... the "leftovers" are brushy thorny dried out weeds ... I used a brush hog on my side probably 6 times this summer, last mowing was with my new to me finish mower ...
Which side looks more "flammable"?
   / Need advice on right cutting attachment #40
Dang pretty fence line. I've got plenty of fence line that could use
your skills. Let me know when you get some free time........:D
2005 IC Corporation PB105 School Bus (A55852)
2005 IC...
Informational Lot - Financing (A56435)
Informational Lot...
2023 Chevrolet Tahoe FL SUV (A55853)
2023 Chevrolet...
RHINO DB150 LOT NUMBER 73 (A53084)
RHINO DB150 LOT...
