Truck Rental Woe
   / Truck Rental Woe #1
ultrarunner
Epic Contributor
SF Bay Area-Ca Olympia WA Salzburg Austria
Cat D3, Deere 110 TLB, Kubota BX23 and L3800 and RTV900 with restored 1948 Deere M, 1949 Farmall Cub, 1953 Ford Jubliee and 1957 Ford 740 Row Crop, Craftsman Mower, Deere 350C Dozer 50 assorted vehicles from 1905 to 2006
The last few years renting a box or stake with lift gate for a day has proved difficult.
Today is the third time in 2 years a rental yard cancelled my reservation… the Penske truck has mechanical issues… last time it was the U-haul was not returned as scheduled and before that a local cancelled unable to provide truck reserved as no longer in inventory.
How do you guys run efficiently with unreliable providers?
I have medical equipment to pick up and would cover about 240 miles round trip…
I don’t want to use my truck and closed trailer because I’m unwilling to spend a morning of my time buying 4 new trailer tires for my car hauler today.
   / Truck Rental Woe #2
I'm surprised your employer doesn't own a truck.
My last employer owned their own truck for just such things, as they had 7-8 remote distribution offices that needed visits fairly often. They also had a couple pickup trucks with caps for picking up supplies, plowing the snow, etc... (plus a whole fleet of newspaper delivery trucks that weren't being used 3/4 of the day). My current employer has our fleet of service trucks and we frequently pick up supplies. They also have a box truck with lift to pick up and distribute supplies amongst their properties. And pickups for grounds maintenance.
On a personal level, we've used u-haul at least a dozen times with 2 college kids moving every year or two, then grad school, then marriage, then houses, etc.... never had a problem with them with advanced registration. From 2 axle trailers to the 26' trucks. Granted, sometimes we had to pick them up 20 miles away, but most were within 30 minutes of our locations.
We found the 2 axle trailers to be the best value, as long as you own a tow vehicle.
   / Truck Rental Woe #3
If you already have a trailer and tow vehicle, I would think that one morning, getting it prepared, would be more economical of your time than finding a rental each time you need it.
   / Truck Rental Woe
The difference is the truck rental is on the clock hours and expense paid for by the hospital…
The hospital will not pay me to rent my truck and trailer…
The half day getting tires would be on my day off and not on the clock.
Sometimes an employee needs to stand firm… plus the hospital always pays the damage waiver when the hospital is renting any type of equipment.
I have used my 4x6 box trailer for short hauls for the hospital… special disposal or things like picking up a concrete planer.
I’m not insured to haul a hundred thousand dollars in operating room tables except as an employee using company provided means…
It could be the availability or lack of rental trucks is just local issue in my metro part of California…?
   / Truck Rental Woe #6
Sounds like you need to get to know a local cartage company. I wouldn't use my own under those conditions ether and your worker's compensation likely wouldn't like you moving heavy stuff if that is not a regular part of your job.
   / Truck Rental Woe #7
i'd hire it out. It's business. if it is a regular thing, they can purchase the vehicle for it if its an irregular thing hiring out makes more sense. To me at least.
  • Good Post
Reactions: JJT
   / Truck Rental Woe #8
Does it Need to be enclosed or do you need the space of a box truck?
Considered a Home Depot F250 with lift gate?
   / Truck Rental Woe #9
I'm surprised you don't have a loading dock and forklift at both ends, and thus shouldn't need a lift gate.
No lift gates, and you could get a consumer grade truck anywhere.
If using personal equipment, then you need an employer willing to cover insurance, or at least sign a contents damage waiver. And probably match a similar rental rate.
Is there a reason that YOU must be at the origin for loading? It really sounds like your employer is trying to go far cheaper than would be typical. They should be able to just hire a normal shipping company for door to door service.
   / Truck Rental Woe
2 operating room tables, 4 gurneys, 3 stainless back tables, lead apron stand, etc.
This is a sister facility that closed and must clear out and vacate by month’s end.
The rate of rural hospitals and clinics closing is accelerating across the country and this is one where the economics no longer worked.
For a long time rural hospitals received a slightly higher reimbursement rate to bridge the gap but I believe this ended… it’s very different in a metro where millions live…
Stretchers are 3’ by 7’6. The operating room tables are heavy but have a small footprint with head and leg extensions folded.
Closed trailer just keeps everything protected in transit.
Lift Gate essential for heavy objects…
Hiring it out would require extra trips I’m sure… plus nothing is palletized which is often preferred.
Maybe all the one way moves out of state have decimated rental truck inventory…
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56138)
2015 FREIGHTLINER...
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
2020 INTERNATIONAL MV607 26FT CDL REQUIRED BOX TRUCK (A56138)
2020 INTERNATIONAL...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A55745)
2014 AMERITRAIL...
2005 Club Car Cart (A55853)
2005 Club Car Cart...
