Tc 33 da whining hydraulics
   / Tc 33 da whining hydraulics #1
Timbo63
Fair grove missouri
Tc33da new holland
How is the best way to check suction side for air entering hydraulic system ? When I check dipstick it has small air bubbles any ideas? When I raise loader or 3 point it whines cold or warm it is hydrostatic drive
   / Tc 33 da whining hydraulics #2
Check the lines leading to the pump, not the ones going from the pump. Tighten all the fittings if you can. Then surround the connections one at a time with with axle grease. That should help you determine which fitting is leaking.
   / Tc 33 da whining hydraulics #3
I may know what you're talking about. I have the same tractor. Check your 3pt hitch lever. Make sure it is not in the fully UP position. If you leave the 3pt hitch lever in the fully UP position the hydraulic motor will whine, and the system will heat up. Whining increases when cold. This situation will cause the hydraulics to whine continuously until you move the lever down and release whatever pressure is building up in the system from this condition. I have learned this over time operating this particular tractor. Whenever you hear the whine, reach down to your right and adjust this lever to break the tension. Always leave the 3pt hitch lever 90% of the way raised if you want to avoid damage/overheating to the system. I don't know why it does this, but that's what mine does and the symptoms sound similar to what you're talking about. Try that and see what happens.
I have always noticed air bubbles in just about every hydraulic system I own. I think this is normal if the machine has been operating but I'm sure someone on here knows better than me.
   / Tc 33 da whining hydraulics #4
It never hurts to replace your hydraulic filter.
   / Tc 33 da whining hydraulics #5
Adjust the feed back linkage and it well stop that. Then you can take the lever all the way up.
   / Tc 33 da whining hydraulics #6
   / Tc 33 da whining hydraulics #7
2021 Kubota RTV-X1140RL-A (A47384)
2021 Kubota...
John Deere 1790 Planter (A50514)
John Deere 1790...
CFG Industrial Q.A Auger (A50121)
CFG Industrial Q.A...
2018 Nissan Sentra Sedan (A50324)
2018 Nissan Sentra...
KJ (9) 5'x5'6" Wire Mesh (A50121)
KJ (9) 5'x5'6"...
Hayrack (A50515)
Hayrack (A50515)
