riderpriderking
Hi Everyone, long time lurker, first time poster. Thanks for all the great advice that you guys put on here, it's been super helpful. I bought a Montana R4944HST (LS R4020H or McCormick CT 47) from an auction a month ago with roughly 1000hrs. I've identified or fixed a number of issues already and I'll post those in the owning/operating form with their solutions another day. For today though I have a problem and I'd like to run it by some great minds before I go out and buy parts just in case my logic is flawed.
My problem is that the loader is slow and weak. It takes about 20 seconds to fully raise (should take 4) and it would hardly lift a couple hundred pounds at the pins (Specs say >2000). It also got progressively worse as it warmed up. After doing some research on here I went out and bought a pressure gauge and some fittings. In the rear remotes the pressure gauge shot up to about 2500 psi and I heard the relief valve whine so that was all good. When I put it in the loader quick disconnects I got about 600 psi in the raise/lower ports and about 650 in the tilt ports. I also did my best to test the cylinders on the loader but since they were only getting 600 psi I figured that they aren't the issue.
The pressure from the pump goes into a distributing block and then into the loaders directional control valve. I looked in the block and saw nothing that would cause any pressure loss.
As an aside I'll describe the block too. One port comes from the pump. The next is pressure out to the loader valve. Beside that are 2 ports that return from the loader control valve's Tank 1 and Tank 2 lines. These ports are labeled R and T on the block. Not sure what R stands for, regen maybe? On the front side is the pressure relief valve. On the last side is a line to the tank and a line to the PTO which continues onto the rear remotes.
Since I had good pressure at the rear remotes and the HST works fine I don't think it's the pump. I can't see how the block can be bad, and the loader cylinders seem fine, therefore I feel like it must be the valve.
The valve is an older version of a Nimco CV112. It doesn't have a relief valve, it just has a plug, which I checked and the o ring was still on it. I checked the cables from the joystick, they seem fine. The spools move in and out ok. I took the spools out, they didn't show any obvious problems. The springs seemed good. The O rings on each end of the spool were there and intact. No external leakage.
So I feel like the valve is the problem but I couldn't find anything obvious. I'm thinking about replacing the valve with a 2 spool MD 30 valve from Princess Auto (ie Harbour Freight in Canada) which has all the same features and schematics, if the mounting screws were the same I'd just have to take off the joysticks, screw in my joystick cables and get some adapters for the ports. But before I spend $300 I thought I would ask you guys since I'm a little stumped on the exact cause.
Thoughts and second opinions are greatly appreciated! Thanks
