Dimensions wanted for deere dump cart
   / Dimensions wanted for deere dump cart #1
Tenn_Blue
N.E Tennessee
Deere 2320, Bobcat 322 mini-ex, Bobcat 763 skidsteer
Ok folks, need some help... I am building a dump cart for my deere 316 from some scrap I have laying around. (Will post pictures and text when I finish.)
I want to build one like the older metal dump carts that Deere made (the 8 bushel one(?!), or something like that...). Have the sub frame and the dump mechanism down, but am looking for the dimensions of the box.
If anyone has one, or knows the size, am looking for the length, width and height of the cargo section, could you post them please. Pictures would be cool too if not too much trouble. My initial idea had been 36" long x 30" wide with removable sides 14" high.
Thanks!!
   / Dimensions wanted for deere dump cart #2
I have one in storage. Must be about that size. I removed the box and used the running gear for making a two-behind spray tank.
If no response sooner, I could dig it out and make some measurements. Don't recall the number on the cart offhand. Been about 12 years.
   / Dimensions wanted for deere dump cart #3
The "book" box dimensions for the model 80 cart are as follows:
Length---42"
Width----30"
Height----11"
Box Capacity---8 cubic Ft.
Rated load cap.--900lbs.
Mine is an early model, although not the oldest. First ones used 4.80 x 8 tires, mine has 16 x 6.50 x 8 tires.
The model 8HD used the same box, but newer style undercarriage.
Hope this helps! ~~ grnspot110
Thanks guys! I knew that there would be somebody out there who had the info handy.
When I laid what I thought the box dimensions should be out on the floor, it seemed too big. Guess it will look better once I get it framed in and on the wheels.
Thanks again!
2018 Mitsubishi Mirage ES 4D Hatchback (A53117)
2018 Mitsubishi...
SET OF (4) ALCOA 24.5 ALUMINUM RIMS (A53843)
SET OF (4) ALCOA...
PREDATOR VACUUM PUMP (A53843)
PREDATOR VACUUM...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
Farmtrac 80 2wd with loader and limb risers (A53473)
Farmtrac 80 2wd...
Bush Hog MB6 960 Box Blade (A53117)
Bush Hog MB6 960...
