I have been troubleshooting an intermittent rear PTO issue. It randomly stops and may or may not start again. Sometimes tapping gently on the PTO solenoid does the trick, but this is becoming hit and miss also. I have a tech manual and have attached a diagram. I have several questions.
How do you remove the solenoid from the valve body?
The PTO solenoid shares a wiring harness with the MFWD solenoid. Do I have to replace both, or is there a way to unattach each from the back of the harness?
Any thing else I should keep in mind?
