John Deere 2240 leaking hydraulic oil geyser front right side with front end loader
   / John Deere 2240 leaking hydraulic oil geyser front right side with front end loader #1
scadatech
Seville
John Deere 2240
Hi,
I recently purchased a John Deere 2240 with the front end loader attachment. Yesterday the hydraulic fluid (gray with m aybe water in it?) started blowing out the right side of the motor just past the oil filler tube near the bottom of the engine. Any ideas? :thumbdown:
   / John Deere 2240 leaking hydraulic oil geyser front right side with front end loader #2
Check flexhoses or steeltube worn throu .
   / John Deere 2240 leaking hydraulic oil geyser front right side with front end loader #3
Even leakoff hose from teservoir to shiftcocer
Thank You for responding. I am attaching a picture in hopes this will shed some light. Tractor.jpg
   / John Deere 2240 leaking hydraulic oil geyser front right side with front end loader #5
Here is a pic from jdparts showing parts associated with the hyd. pump.. on front of engine. Don't know if it helps you directly.
You can go to this link and put in the model no. and browse to track down the part suspected of leaking and get the part #.
John Deere - Parts Catalog
Thank You!:drink:
Update: It turned out that there is a 3/4 inch hose at both ends of the metal tube on the right side of the motor just behind the radiator. I replaced both hoses and all 4 clamps, added hyrdraulic fluid and all is well.
Thank all of you for your reponses they were very helpful.:thumbsup:
   / John Deere 2240 leaking hydraulic oil geyser front right side with front end loader #8
scadatech
If the hyd fluid is gray which indicates moisture in the hyd oil you need to drain oil to get rid of moisture. Moisture in oil will cause brake linings to deteriorate quickly causing metal to metal contact then fine metal gets into hyd valves causing problems.Common places for water in oil are cracked shifter boots & clogged hyd oil reservoir breather.
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
2022 CASE TV370B SKID STEER (A51242)
2022 CASE TV370B...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
1994 Toyota 6000lbs 2 Stage Forklift (A52128)
1994 Toyota...
2012 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2012 VOLVO VNL...
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
