Kioti DK40SE starting issue
   / Kioti DK40SE starting issue #1
prollynotjeff
Member
NY
Kioti DK40SE
The issue started about 6 weeks ago, I was working in the woods in a wet area digging a diversion ditch. A bad storm came In and I left the tractor and walked back to the house(much faster). It rained heavy for 30+ minutes. I went back about 3 hours later to get the tractor and the issue started, the motor would crank but it wouldn't start. After a few attempts it started, I parked it in my barn and after a week of drying out the issue seemed to go away, once and awhile it would take an extra try to start. Tonight (warm and dry) it started right up, I was doing yard work so the tractor was on and off a few times but then the hard start issue came back. It will crank and crank but not start. It hasn't left me stranded yet but today it did take 6 attempts to start. Any ideas?
Kioti DK40SE
Gear drive
165hours
Thanks!
   / Kioti DK40SE starting issue #2
IF a diesel cranks, and fuel is delivered at the correct time as controlled by the injector pump and the engine has compression and the temprature is sufficient in the cylinder, it must start. Which one are you missing?. The fuel solenoid relay is a notorious failure point, and does not pull the fuel stop solenoid. The solenoid has two windings, the pull winding, and the hold winding. The pull winding is powered by the fuel relay and it duration of 1 second is initiated by a ground that comes out of the display unit for 1 second. Do you hear the Clack of the relay and solenoid. Did you measure the 1 second 12 volt pulse on the fuel stop solenoid on the front of the injector pump? The other winding is held by the key buss to 12 volts continuously. This is a low current winding and when you turn the key to the off position, this makes the fuel solenoid relax and the spring pulls the rack in the injector pump back. The engine dies for lack of fuel. The glow plug system is a high current draw system that energizes the 4 glow plugs and pulls nearly 70 amps for about 15 seconds in the automatically initiated cycle that is controlled by the pre heat relay. This is the 70 amp rated relay on the firewall, usually in the center position of the three relays on the firewall. You can measure the 12 volts nominal on the glow plug buss. It also has a post glow function, that continues to heat the combustion chambers for 15 seconds AFTER the engine has started. This is not reflected in the "glow" lamp on the dash, but it occurs. If the failure to start is occuring soon after you shut it off, it is NOT likely the pre heat circuits and relay. Because there is a temprature sensor that prevents glowing if the temp is high enough to not need it. Such as when it has been running and you shut it off and attempt to start again. My money is on the fuel stop relay. Second guess would be the fuel solenoid. But the relay is notorious for failure. They are a dime a dozen on Amazon or E bay. Or at your favorite auto parts store.
Thanks for the tips I hope to check this weekend
   / Kioti DK40SE starting issue #4
What is the correct amazon link for the relays? The relays and the ignition switch are the DK's weak points.
I found 3 on the firewall, does anyone have a picture or diagram showing what ones what? I need to purchase a repair manual I suppose. Thanks for the help and links guys!
   / Kioti DK40SE starting issue #8
Here is the photo you requested... Yes, you really should buy the manual. Your tractor isn't getting much younger and will always need servicing throughout its life. :)
   / Kioti DK40SE starting issue #9
It appears it was the ignition switch, Everyone thanks for the help!
Swict 7' Fork Extensions (A50121)
Swict 7' Fork...
Portable Fuel Tank (A50515)
Portable Fuel Tank...
2005 Mack Vision Semi Truck (NOT RUNNING)(TITLE) (A50774)
2005 Mack Vision...
2016 Wilson Hopper Bottom Trailer (A50514)
2016 Wilson Hopper...
1984 ASPT 30ft Pole S/A Towable Trailer (A51692)
1984 ASPT 30ft...
2015 Jeep Renegade Latitude SUV (A50324)
2015 Jeep Renegade...
