Moving Logs
   / Moving Logs #1
SpinyMouse
New Hampshire
Kioti LK3054XS
Occasionally, people ask about moving logs with their tractors. My LK3054xs moved this 14' long by 19" diameter white pine log with zero trouble. Both the FEL and the 3PH lifted an end of the log without a hiccup.
   / Moving Logs
Here's a second shot.
   / Moving Logs
I had plenty of traction to move the log even while going uphill on wet dirt.
   / Moving Logs
Last picture.
The hardest part was figuring out how to wrap the chain so the 3PH could lift the log without letting it roll over.
Once I had the chain hitched up properly, it worked like a charm. Most of the chain you see in the picture is actually excess, which I led into the bucket to keep it out of the way.
   / Moving Logs #5
That's a pretty neat skidding set up.
I'm having to do a lot of it myself after the storm about a month ago. I still have a couple of downed trees to remove from the pasture although I've got all the ones around the house. Still have the board fence to fix but I'll get that next week, if it ever stops raining.
Can I ask where you got the set up from, was it bought or homemade? I could sure use one but I don't have the time to make one right now.
   / Moving Logs #6
Good Job! My CK20 will pull them that size too. Who'd have thought it? John
   / Moving Logs #8
</font><font color="blue" class="small">( A log my little B7100 managed to pull.
Egon )</font> Good size log, 3 or 4 of those and you are all set for those NS winters as firewood goes,not bad for a tractor barely bigger than an ATV. /forums/images/graemlins/wink.gif
   / Moving Logs #9
That will not be firewood. I'll manage to turn it into much sawdust and perhaps a couple of boards. Got two more just like it.
Egon
   / Moving Logs #10
</font><font color="blue" class="small">( A log my little B7100 managed to pull. )</font>
Another good example that bigger is not always necessary. I hope aspiring tractor buyers will see this and understand that these smaller tractor can often be all they need. John
UNKNOWN TANK MANIFOLD (A58214)
UNKNOWN TANK...
2011 Toyota Camry Sedan (A56859)
2011 Toyota Camry...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
(INOP) JLG E300AJP ARTICLATED MANLIFT (A60429)
(INOP) JLG E300AJP...
1999 Featherlite Gooseneck Livestock Trailer (A59814)
1999 Featherlite...
Zero Turn Mower (A59231)
Zero Turn Mower...
