Foodplot
This thread should probably be entitled 'in praise of the square U-bolt'.  With school out, I had some downtime, so have been accessorizing the L3400.  I've seen several posts on where/how to mount brackets for a toolbox and for the valve for hydraulic remotes, so thought I'd share mine.  Both are attached to the ROPS via square U-bolts.  Others on TBN have mounted the hydraulic valve similarly, but on top of the ROPS frame.  I like the levers closer to my hands, so I simply modified their ideas by offsetting the mount below the frame by 6 inches.
In the last picture, note I also used square U-bolts to move the SMV sign up out of the way of my boom pole and post hole digger, and to mount a rear worklight. Hope this helps if you're looking to do something similar.
