aczlan
Good Morning
- Joined
- Mar 7, 2008
- Messages
- 16,964
- Tractor
- Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
We have a Kubota B7500 which has had a sloppy loader control for as long as I can remember, it got to the point where the lever hit the steering wheel when you went all the way to the left (full curl).
I finally got tired of it today, took it apart and replaced the bushing for the pin that goes up and down. I think the bushing that was in there before was steel. I replaced it with a half inch copper pipe coupling which was just right diameter once I removed the old bushing with a 11/16 drill bit and was only a little bit long. I cut it shorter with a pipe cutter and it was good to go. $0.89 was a good price to tighten up the control lever for the valve.
I didn't think to get any pictures before I put it in, but here are a couple pictures with it in place and one of the old bushing after I drilled it out..
