JimP
- Joined
- Nov 21, 2004
- Messages
- 237
- Location
- southern New England
- Tractor
- Kubota L5460HSTC; Volvo ECR88 excavator; Dresser TD9H dozer; Bandit RM990 chipper (sold)
So, my son was brushing hogging a field yesterday with the 5460 Grand L and ran over a stump. It ripped off both of the 3rd function hoses in back of the right front tire; pushed up the fuel tank cross over line protection and dented one of the hydraulic filters. Tractor was blowing hydraulic fluid so we shut it down quick. One of the fittings cross threaded back on loosely. Threads in the other fitting were too far gone for it to go back on. Tractor couldn't be run without blowing gallons of hydraulic fluid everywhere and was dead in the field and needed to be towed back with the pickup.
Some of the fault is ours for not having the grapple down low enough to catch the stump before it went under. However, the 3rd function setup is poorly designed and more poorly protected. Other parts under the tractor are also soft if you work in anything but grass as I have previously pulled out sticks that had become wedged underneath. KUBOTA - ARE YOU LISTENING. THE THIRD FUNCTION NEEDS A REDESIGN AND THERE NEEDS TO BE A SKID PLATE OPTION FOR THESE MACHINES. Rant off.
Interestingly, I have not had any problems with the loader hoses or connections or fuel fill hose though other than the front wheel throwing slush on them in the winter.
So, has anyone made or bought a skid plate for a large frame Grand L? I will also be trying to reroute the hydraulic hoses to a more protected location.
Jim
Jim
