Tool Box
   / Tool Box #1
jaydee325
Casco, Mi
John Deere X584 Garden Tractor & LS R3039H
Put a tool box on my R3039H.
Box is a poly ammo box from Cabela's. It is a nice small water proof box that is less than $10.00. Used existing threaded holes on the tractor so no drilling required.
Bob
   / Tool Box #2
I put that same box in place of my SMV sign. I"ll have to get a pic to share.
   / Tool Box #3
On my R3039 I took off the right step and mounted a toolbox.
   / Tool Box #5
here's mine, I got the box from HF and made an angle iron frame for it, I unbolted the original step and created a frame using the existing bolt holes. I can take the box out if I need to but I just leave it in with the tools and pins, etc, i need for the tractor. 20140117_140203.jpg
   / Tool Box #6
Just got an ls 3037 and need a toolbox. How did u attach yours?
   / Tool Box #8
Here is mine. It is a metal 50cal ammo can in a bracket I welded up and attached to the right step bolt holes. Fairly easy and convenient! Capture.JPG
   / Tool Box #9
My tractor doesn't have a step on the right side so I will probably mount mine here too ! I like the 50 cal. box . Nice having tapped holes to use huh?
   / Tool Box #10
Here is mine. It is a metal 50cal ammo can in a bracket I welded up and attached to the right step bolt holes. Fairly easy and convenient! View attachment 569753
I like how you went to the extra effort to build a frame for the amo box to mount it.
Where did you get the LS Blue paint ?
That is a real neat job and i think i will copy it for my XG3135 thanks!
BETSTCO FMN120 -4' FINISH MOWER, 3PT (A52708)
BETSTCO FMN120 -4'...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
JOHN DEERE 165 HYDRO RIDING MOWER (A58374)
JOHN DEERE 165...
LOT OF TIN (A58374)
LOT OF TIN (A58374)
2012 BIG TEX PIPE TRAILER (A58216)
2012 BIG TEX PIPE...
2020 Ex Mark Lazer Z 60in Zero Turn Commercial Mower (A55973)
2020 Ex Mark Lazer...
