npaden
I *might* have found the problem. Last night I found a schematic online for the Zexel pump. It showed a screen at the inlet line. Pulled it this morning. It was pretty well clogged: almost to the point of not being able to see light through it. I blew it out with air (hold tighter next time so I don't lose it across the barn floor!). Reinstalled it, tightened things up, purged the air, and started it up again. Way higher RPM! No surging or "missing". I'll have to go mow a field or something to see if this truly fixed it or not. Keeping my fingers crossed.
Here's a pic inside the bottom of the old fuel filter I took off. Pretty ugly.
Now, as to the red fuel line: that's how it came from the factory. I don't know. If it has deteriorated inside, maybe that's why that small screen was clogged instead of that stuff being caught by the filter? I'll get a new piece today.
Where was that screen? I have the same pump and have been having very similar problems. I also had a red fuel line. Is it that fitting right there at the inlet? Just pull it off and the screen is under it? Thanks!
