Binding Tractor to Trailer
   / Binding Tractor to Trailer #1
Chrisb009
Mahindra 2645 Cab
Greetings,
I am really surprised there are really no binding points on tractors today (after all theses years). When I picked up the 2645 cab I had to wrap chain around the rear axle and front axle pivot point (rear was a pain to do with a bush cutter attached). So I decided to install some binding points. On the front, each side of the front frame, I simply added 1/2 d rings with plate (available across the counter locally). The front d rings are heavy duty and can be used for light to some heavy pulling. The rear was a little more challenging in finding a spot to mount some sort of binding point. The idea I came up with was to have 3/8" plate metal bent at approximately 45% angles on the edges. This plate would bolt the lower rear axle area via the two lower bolts. I took the idea came to a local machine shop known for doing small lot and specialized work. I worked with their CAD / CAM engineer and after several iterations we had a electronic prototype. Once I approved, it was made on the shop floor. I picked it up Friday and am very pleased with the outcome. It gives me rear binding points and also will allow for some light duty pulling from the attachment points as well. Attached a picture of the bracket. I had two made so if someone it interested in the second reach out - will sell cheap in comparison to what it cost to have it custom fab'ed and made.
Thanks,
Chris
   / Binding Tractor to Trailer #2
I"m not sure I understand how or where you are mounting the attachment. It will be interesting to see some pictures when you get it installed.
I've included a picture of the mount location - look to the right side, where bolt is missing. It mounts in that location using the missing lower right bolt and left side lower bolt. I have to paint the bracket before I can install it so it may be a few days before it's warm enough to paint.
   / Binding Tractor to Trailer #4
I think it would have been better to make a plate that mounted across the drawbar than to rely on just those 2 bolts going into the housing. The drawbar has it's forces across all 4 bolts there as well as the ones underneath. Just something to consider. I simply put a clevis in the drawbar and run both rear chains or straps to the clevis.
I gave it some thought but decided on a dedicated bracket using the two lower bolts. From the research I performed it appears the rear housing and two lower bolts are sufficient to withstand the forces being applied.
Thanks,
Chris
   / Binding Tractor to Trailer #6
I think Bearsixty7 has a better answer. Why make/use something questionable when you have the drawbar right there.
Not so sure why this would be questionable - after performing the research the rear two bolts are more than strong enough for this application. The drawbar allows one point of attachment for the rear portion - federal specs outlines four attachment points when transporting heavy equipment (have driven OTR). This doesn't necessarily fall into the heavy equipment range but I'm used to over designing to eliminate possibilities. This should also satisfy the motivated LOE.
Thanks,
Chris
   / Binding Tractor to Trailer #8
On my 2565 I just tie to the drawbar pin. If for some reason I need to tie further forward due to an implement attached to the 3 point, I can just turn the drawbar around, slip in it from the front. As far as 4 point tie down I just run a separate chain from drawbar pin to each side of the the trailer.
The concern I have with your setup is if you get in a hard braking situation while hauling the tractor you really only have one of those bolts holding the load. If your tie down point was between the bolts then both bolts would be holding the load. As it is, the bolt is being stretched and pealed sideways, in other words, it isn't a straight pull against the bolt.
That's correct - side forces would be applied to one bolt however forces in a direct line would be applied to both bolts. If braking, in a straight line, the force would be applied to both bolts if the load was properly bound to the trailer as both 45 degree attachment points would be load bearing in such a situation. I don't see having side forces exceeding a grade 8 bolt capacity however it could, in an extreme situation, exceed the housing strength and rip threads from the housing. The housing would be my concern when taking side forces into consideration but of no concern when considering straight forces such as braking in a straight line. The side force to rip threads from the housing at a 45% angle would have to be of an extreme nature - one I don't ever plan testing.
Thanks,
Chris
   / Binding Tractor to Trailer #10
I carry two clevises of different styles. I almost always use a clevis on the draw bar. I second the others on not risking damaging that housing.
1997 MONON 102" X 53' T/A VAN TRAILER (A51247)
1997 MONON 102" X...
New Holland 1745 (A50123)
New Holland 1745...
2022 LOAD TRAIL INC GP0240122 LOT IDENTIFIER 251 (A53084)
2022 LOAD TRAIL...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2016 FREIGHTLINER...
2005 Freightliner M2 106 Dumpster Carrier Truck (A51692)
2005 Freightliner...
Ford Tractor (A50120)
