martingsutton
Hi
Have just bought a French version MF 135 first registered in 1972.
The type on the plate is 135 8S although on the reg doc it says 135 85.
Serial number is R522146 and says it was built by Massey Ferguson S.A. Le Plessey Robinson, France.
The first thing I want to sort is the type of engine. All early French versions had the Perkins A.3 - 144 engine. I have found a 500 page (in French!) service manual that gives info for the A.3 - 144 engine and the AD.3 - 152 that in France was fitted to later models such as MF 245 but was standard for the MF 135 in the UK and the USA.
Is there a straightforward way to check which engine I have? I assume at some stage they switched to the AD.3 - 152.
There are two numbers on the engine block, 37111280/4 is above the injectors and MC 25210 A is below. The gears are 6 forward and 2 reverse.
Can anyone advise please?
Thanks
Martin
Thanks
Martin
