slhilbert
I recently replaced my clutch and I am in the process of putting everything back together. The wiring is killing me. The dealer copied off the wiring for my MF 135, 3 Cylinder Perkins, Gas.
I followed the diagram to the letter except for two things.
1.) The Fuel Shut Off Solenoid that comes from the Starter Solenoid is not present
2.) My Ammeter gauge appears not to be working so there is wire connecting the two posts together.
The result is that the tractor turns over but the starter will not disengage, it just keeps cranking away until you turn the key off, basically the "Run" position doesn't disengage the starter.
I messed around with it for a while, and decided to wire it per these directions I found in a forum.
The result of this wiring is that the starter starts as it should, but the coil isn't getting any voltage so when you turn it to Run it dies. I went ahead and ran a wire from the positive post of the battery to the coil and the engine continued to run.
I some how managed to wire it yesterday so that it started and ran, but you couldn't turn it off.
I have a 3 post key ignition, could that be the issue or what? Is the fact that the Ammeter gauge is bad an issue?
Thank You,
Stuart
Thank You,
Stuart
