Building a Thumb for excavator
   / Building a Thumb for excavator #1
tylertown
MS
Massey Ferguson 40 backhoe, Ford 5000 general purpose
Hi I currently have an e35sr NewHolland mini excavator and I really like this machine small but very strong. I am wanting to go with a thumb on it now but I don't want to fool with a mechanical thumb I want hydraulic thumb but don't want to pay over a thousand dollars for one. im wanting to build one. I heard that the local tractor supply store has hydraulic cylinders for sale with varying sizes. want to make my own. any ideas? Thanks guys
   / Building a Thumb for excavator #2
Not hard to I took a mechanical one and just added a cylinder just remember though everything you hang out there decreases how much you can lift and changes the balance of the machine a bit.
   / Building a Thumb for excavator #5
This is the Hydraulic thumb from Showtime Fabrications, it is built very heavy.
John
Thanks very good information! lots of great options!
   / Building a Thumb for excavator #7
If you can use a CAD program, you can draw a thumb to fit your bucket. Put it on a thumb drive and take it to a steel mil where they will cut out the parts for you.
If you do it right, the parts will go together like a puzzle
Get an estimate first.
   / Building a Thumb for excavator #8
Do you already have aux boom hydraulics? If yes, that's a bonus. If not, then you'll have to figure out valve placement, hose routing etc also.
Can you find your same machine that has a thumb already and copy it? Easy enough to build, even easier if you can copy the geometry and sizing from an existing one
   / Building a Thumb for excavator #9
Can you find your same machine that has a thumb already and copy it? Easy enough to build, even easier if you can copy the geometry and sizing from an existing one[/QUOTE]
Good advice. This is always MY "plan A' or 'go to' plan.
Good luck and give us updates on your adventure.
Terry
   / Building a Thumb for excavator #10
This is what I was thinking. I don't know how to use a CAD but my engineer brother can. However he's busier than a one armed paper-hanger. If I do a good 3-view drawing it might work. I don't need an exceptionally big or strong one; just for occasional rock moving.
I may do a plywood mock-up first.
10' Feed Bunk (A50515)
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
