Dye for Hydraulic Oil
   / Dye for Hydraulic Oil #1
WranglerX
Super Member
A Little Bit West Of Yosemite NP
MF GC1715
Have a MF GC1715 and it has a "sight glass" for checking oil in HST, trouble is oil is so clear you can not tell if it is above or below sight glass (have yet to see oil level in glass) but upon using a piece of wire as a dip stick I sort of determined oil is above sight glass...
Question is there a dye one can put in oil to make it more visible (like dyed red diesel)? ... Something that will not break down oil or react to various components of hydraulics and HS drive....
Dale
   / Dye for Hydraulic Oil #3
Just search for compatible leak detection dye.
   / Dye for Hydraulic Oil #5
John Deere dye is best, compatible.
   / Dye for Hydraulic Oil #6
I purchased a 2oz sample of the novasolve red, 3 eyedropper sized drops will color a quart of oil
   / Dye for Hydraulic Oil #7
I bought this red dye through Grainger. I had contacted the company, Kingscote Chemicals and they sent me an info sheet on it. You need very little of it to color the oil. It can also be used for engine oil. This is sraight dye, not one that requires a special to see like leak detection dyes. You don't want the fluorescent one, just the regular color one.
KINGSCOTE Color Coding Dye, Red, 4 oz. - 45H15'|'5-R4 - Grainger
   / Dye for Hydraulic Oil #8
The aforementioned JD dye worked great for my L3200 with a crappy sight glass. Used half the bottle. Went to put the other half in the new L4060 a few years later & it was dried up. Either I didnt get the cap on tight or it doesnt last for a few years on own.
Had to inform the buyers of the L3200 what I did when I sold it so they or their mechanic wouldn't think I filled it with ATF as that's what it now looked like.
   / Dye for Hydraulic Oil #9
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54607)
2019 FREIGHTLINER...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A52377)
1993 Ingersoll...
2017 KENWORTH T800 (INOPERABLE) (A53843)
2017 KENWORTH T800...
2014 KENWORTH T800 MIXER TRUCK (A53843)
2014 KENWORTH T800...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
