m5040
- Joined
- Nov 23, 2008
- Messages
- 1,012
- Location
- CT
- Tractor
- Kubota M6040 L2250, JohnDeere 310D, Ford 841 Elenco, Ford 961, Trapmaster, PT180 w/LM bucket and 45" brush cutter, PT1430 Deutz w/grapple bucket, Antonio Carraro Tigrecar 6500. John Deere 5300. Former owned Steiner 430 max, Goldoni REV Maxter 7
I wanted to used SSQA (skid steer quick attachments) that I already have on the 1430, so I orded a 3pt to SSQA adapter off of fleebay. The T12 plate fits in pretty nicely.
I measured the PT bucket for the angle they want to use as a neutral starting point and figured it was 30 deg. So I welded the T12 plate inside the structure of the adapter at that angle. Will have to see how it works when I get a chance.
Just a note, I am not saying that the ebay adapter is good quality. I tried it in one attachment and it fit, loose. Which is better then my Lackender fork attachment that I couldn't lock in one dog and was told you don't need down pressure on pallet forks. I was thinking of that before I welded in a $200 PT blank plate and if it didn't fit they would say to just send it back......
